Thread: Polaris 360 Question
    I was told at a pool store that I could use this Polaris 360 in my above ground pool, since it is a 18x38 size and steel walls with vinly liner.
    Has anyone ever heard of this being used in an above ground pool and if so, does it work good?
    Thank you!
    Nora Rodriguez
    Waxahachie, TX
    AGP 18 x 38 Oval
    Sand Filter & 1 hp pump
    Pool Clown's Avatar
    Sep 2008
    Silicon Valley, CA
    1,695
    Re: Polaris 360 Question
    I have not put one in a liner pool, but i heard that you have to get "liner tires" made of a littler softer compound so the unit can get better gripsion. (is that a word?) But that has been awhile since i heard that. Can't hurt to ask.
    Factory Warranty Station for:
    Thank you for your information and I will look into those tires.
    Nora Rodriguez
    Waxahachie, TX
    AGP 18 x 38 Oval
    budster's Avatar
    Dec 2008
    Savannah Historic District
    272
    Though not designed as an aboveground cleaner, I have seen successful use in the larger ones. The trick is to get the right pressure to it.
    http://www.swimmingpool.com/
    "Leave the gun...take the cannolis"
    I have been using this cleaner and It is doing a WONDERFUL Job!
    Nora Rodriguez
    Waxahachie, TX
    AGP 18 x 38 Oval
