Results 1 to 7 of 7
Thread: First shock.
    First shock.
    Do I need to use a shock product or can I shock my pool with a high level of my normal chlorine product?
    Thanks in advance.
    _________________
    35k gal 850sq ft french gray plaster, Jandy JEP1.5HP ePump, Pentair 60sq DE filter, Pentair Intellichlor IC40, 10 Fafco sunsaver 12'x4' panels with Goldline GL35. Laars lite 325k BTU NG heater, Hayward Colorlogic 4.0 LED light. Plumbing: 2" PVC, No main drain, four 1" returns, 1 skimmer with 2 wall drains, one 1.5" suction cleaning port.
    30,419
    Re: First shock.
    Welcome to the forum. What is your chlorine product you normally use?
    May 2008
    Virginia Beach, VA
    84
    Re: First shock.
    If you are thinking of using powder based chlorine to shock the pool, most folks in this forum will warn against it... powdered chlorine is stabilized which will add CYA to the pool. Some powdered shock contains calcium, some contains copper, some is based on MPS. So using any of these to shock the pool can cause additional problems.
    The chlorine form that has the least additional byproducts is liquid chlorine, or bleach. It's cheap, easy, and effective, and you minimize additional chemicals in your pool.
    Good luck!
    28K IG Vinyl lined pool - 1 skimmer, 2 returns
    Hayward DE 60sqft filter; Polaris 280 vacuum with booster pump
    Re: First shock.
    Hi there,
    Thanks for the quick responses.
    I'm in Italy so the chlorine I've got is called ACN63, by Acquaclinic, an Italian company (I think). It's a powder product.
    It says on the box that I can use a higher dosage of it to shock the pool, but I've heard of Shock products and wondered which was the best route to take.
    _________________
    30,419
    Re: First shock.
    Liquid chlorine (cleach) is the finest chlorine product to shock with.
    All the powders add something to your pool that you don't want. Without test results and without the ingredients in the powder, I cannot tell you if a few doses of it are okay but long-term, I would suggest you not use whatever it is.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: First shock.
    I always wondered how to say bleach in italian ;)
    30,419
    Re: First shock.
