Results 1 to 11 of 11
Thread: to cover or not to cover
    Mar 2009
    eastern washington state
    275
    Hi Well i guess we are going to go and stimulate the economy this next week, we are going on vacation for 5 days... I am going to raise the FC to shock level.. But i was wondering is it OK to cover it up with the solar cover?
    thanks jim
    live in eastern washington state
    18x36, Vinyl inground 24k
    Hayward 1 hp filter pump
    1 skimmer/2 returns
    24" sand filter, polaris 280 with booster pump.
    keri1973's Avatar
    Apr 2009
    Pensacola, FL
    74
    Re: to cover or not to cover
    Thats what I plan on doing in a couple weeks.
    18ft. Arcadia Round AGP - 19" Sand Filter, 1 hp pump
    Foam cove/ Gorilla Pad/ Wedding cake steps
    Sta Rite Lil' Shark cleaner and Aquabot Pool Rover cleaner - Aqua-Luminator light and return flow w/fountain attachment
    Added Borates 5/19/09 Taylor K-1005 and Taylor FAS-DPD Chlorine Tests
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Yes, it's fine. I have a dk blue/black solar cover. I shocked to 16 June 4, covered, returned 10 days later and my FC was 8....
    Jan 2009
    Cupertino, CA
    1,966
    I'm leaving mine on while I'm away for the next week, even though the water is already at a toasty 92F. (It's been warm here lately.)
    --paulr
    BBB "Intermediate Swimmer"
    Mar 2009
    275
    is it better to cover or not... is the Fc to high to cover for that many day.
    thanks
    1 skimmer/2 returns
    11,969
    I was gone 10, and had no problems...
    Mar 2009
    275
    cool, thats what I am going to do... i sure am going to miss her(pool) i will have dreams of her(pool) but she will be ready when we get back....
    thanks guys
    jim
    1 skimmer/2 returns
    Quote Originally Posted by hayfarmer
    thanks guys
    jim
    That's funny, but I do love my pool. I hate getting invited to someone else' party because I will miss my pool
    16,000 Plaster/Gunite - Pentair FNS Plus Fiberglass D.E. Filter
    Heat Siphon Heat Pump Z375HP- Hayward Pro Logic PL-P4 Automation
    Hayward Chlorinator Cell T-CELL-9 - Waterway SVL5 Pump
    A.O. Smith Two Speed Motor B983 - Solar Blanket - Polaris 380
    Test Kit K-2006c
    One issue I've had with covering is the small pockets of water that you often get on the cover, which don't circulate.
    I ended up with an algae bloom after taking off the cover, and not having sufficient chlorine in the rest of the pool (was only FC of 3, CYA 60, which isn't TOO bad). My suspicion that I can't prove is the pockets of water gave the algae a chance to get established, then it spread when I took the cover off.
    If I ever use the cover for a long period away again (which will keep the FC in the whole pool higher), I might bump my FC up higher before taking the cover off to prevent that.
    Jim
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Quote Originally Posted by Rob
    not too bad since it wasn't 0? you're below minimum which = algae sooner or later assuming no other algae defeating products.
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    Quote Originally Posted by frustratedpoolmom
    Followed Mom's example to the T and I was gone 10 days the only 10 days of summer we had...temps were 85 to 95 for the entire time...When I left FC was 16 and I covered and when I came back FC wa 6. I was glad because water temp was almost 90. If I had not brought FC up so high and did not cover I would have no FC when I got back and I would have had algae. The Solar cover keeps the FC from decreasing too much due to evaporation. Trust in Poolmom
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
