Thread: Type of Chlorine in Defeating Algae and Shock Your Pool
    Mar 2007
    San Rafael, CA USA
    12,082
    I think that both the Defeating Algae and the Shock Your Pool articles in the Pool School should explicitly mention that the preferred source of chlorine in these cases is chlorinating liquid or bleach, though Cal-Hypo may be used of the CH is low. Trichlor pucks/tabs should not be used as they are too slow to dissolve, are too acidic, and increase CYA. Dichlor should not be used either since it increases CYA by a large amount.
    Re: Type of Chlorine in Defeating Algae and Shock Your Pool
    Sounds like a good idea, especially since people are already tending to use trichlor and dichlor, which are adding to their problems in the first place!
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
    30,421
    Good thought, Richard. We recommend that when we respond, so it should be in Pool School, too.
    I added a statement that is best to use bleach or liquid chlorine to each of those articles.
