Thread: GPM Flow meter for heater line
    Jul 2008
    Flintstone, GA USA
    112
    Just installed Hayward 250,000 BTU natural gas heater and it says to install a flow meter to make sure you are getting the proper water flow through the heater. Where can I find one that does not cost an arm and leg. Also does it install between the filter and the heater inlet port or does it install between the heater return line and the chlorinator?
    Any help would be greatly appreciated.
    Thanks
    Tom
    18 x 36 Grecian Polynesian Fiberglass Walls with Concrete bottom - 3 ft to 9 1/2 ft. deep -
    Hayward Variable Speed Super Pump SP2600VS 1 1/2 True HP,Hayward sand filter S200, and Hayward auto clorinator. Hayward 250,000 natural gas heater. PoolKeeper automatic water leveler. Loop Loc Ultra Solid Safety Cover. Hayward Color Logic 12 volt light. Dual Pool Deck Jets.
    Polaris 380 auto cleaner. Trouble Free Test Kit TF-100.
    30,419
    Re: GPM Flow meter for heater line
    Hi, Tom,
    Few people use a flow meter.....while convenient, they simply aren't required. The price is always high, to my knowledge.
    While I do not have a heater, I would be happy estimating my flow from the pump curve and the end result of how much heat was entering the pool.
    mas985's Avatar
    Pleasanton, CA
    11,737
    I agree with Dave, you really don't need a flow meter and with a 1 HP pump, there should be no issue at all of having too little flow rate. If you have a two speed, low speed may be a problem but the Hayward heaters should have a low flow switch which will shut off the heater when flow rate gets too low.
    Mark
    Jul 2008
    Flintstone, GA USA
    112
    Thanks for info. I checked with the local pool supply store and they have flow meters but told me the same thing. I do not need one. He said they only had them because it is a law that all commercial pools have one. He said of all the residential pool he had seen and worked on he never say a flow meter installed on any of them.
    Tom
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    The only time my heater won't work on low speed is when the filter is dirty... that's when I know time for a cleaning...the psi guage doesn't budge - but the heater won't work.
