Thread: Calcium hardness test
    Cincinnati, OH
    2
    I recently found this site when I couldn't get my local pool stores to figure out what was up with my pool. This site has been great. Thanks! I've received my test kit and have a question regarding the calcium hardness test. Do I swirl to mix in between drops or simply keep adding drops until the color changes to blue? If I swirl I get a reading of 350...if no swirling it's closer to 500 !!
    IG, Gunite
    23,000 gallons
    Hayward Super Pump 1.5 HP, Hayward pro-series high rate sand filter - 300 lbs
    sun from 10am - 5pm
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Calcium hardness test
    The CH test is tricky.
    You swirl for 20-30 seconds in between drops. The test should take you several minutes to complete properly.
    Cincinnati, OH
    2
    Thanks! Now if I can only get comfortable with the CYA test
    IG, Gunite
    23,000 gallons
    sun from 10am - 5pm
    frankthailand's Avatar
    Apr 2008
    Thailand
    152
    http://www.taylortechnologies.com/Chemi ... ntentID=44
    Try this link for some info on the CYA test.
    happy swims
    Frank
    Hello all from the land of smiles. Thailand. 5mx9mx1.5 63000L 16300 gall, pebbletex,
    pentair 1hp whisperflow, tagelus TA60 SF, swg monarch esc24 {a bit small for the tropics} 3 returns, 1 skimmer, 2 astral 100watt lights. Planned and built by me
    an AUSSIE expat living thailand for 18 years.
