Thread: New liner & fresh water being put in tomorrow! Now what?!
    Hi everyone
    After a 3 week wait our new V-bead liner should be getting installed tomorrow. Once the pool is filled with fresh water the first thing I need to do is to add the appropriate amt. of cyanuric acid for a 20,000 gallon pool, right? I'll consult a pool calculator. OK, easy enough.
    I'm assuming after waiting 3 or 4 hours I can test the CYA level and add more if needed, right?
    Then, using the BBB method, would you then add a few gallons of bleach, wait a few hours, and focus on getting the chlorine level within the appropriate ranges?
    I'm guess I'm trying to figure out what chemicals are the priorities in terms of which need to be balanced first, second, etc.
    As always, any and all help is needed and much appreciated!
    Thank you!
    Jeannie
    Connecticut
    30' round AG / 20,000 gallons
    Cartridge filter
    BBB method user since '08 and have never looked back!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: New liner & fresh water being put in tomorrow! Now what?!
    No. First adjust PH.
    Then you can add CYA, but you wait a week to test for it. Add enough to reach a target of 50ppm, you want to make a slurry and pour it slowly thru the skimmer. It will slowly dissolve in your filter, so you can't clean or backwash for a week. Normally we advise a sock in the skimmer or in front of the return, so you can backwash, etc. if necessary, but since this is new water I can't see you needing to backwash....so go ahead and add it directly. Leave the filter running for 48 hours.
    After you are done adding the CYA, start with the bleach. Use the Pool Calc. A good starting point would be 5ppm, which is not necessarily "gallons".
    Check FC twice a day and add bleach to stay above 2 at all times, until the CYA starts to work. 24 hours after adding the CYA, use the 50ppm level on the CYA chart and those are your "target" and "min" levels.
    Been away. Thank you so much for your response! For some reason, perhaps from being sleep deprived I thought I recalled your response saying to add CYA first and THEN adjust PH. Just shoot me, So I basically put 4lbs. of CYA in the pool skillmer basket and then added my borax which I mixed in a pail and poured in front of the return. I am going to wait a few more hours and test the PH. I'm actually scared to look in the pool. I hope I didn't screw up royally by doing this backwards.
    Jeannie
    (who is off to get coffee and very annoyed with herself! )
    Connecticut
    Cartridge filter
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    Don't worry, you should be alright. I believe the main reason PH is adjusted first is because if it's way out of whack, it will cause damage long before not having any CYA.
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    Thanks Adam. I breathed an audible sigh of relief when I read your reply! This site and its members are the best!
    Jeannie
    Connecticut
    Cartridge filter
    11,969
    LOL, you're fine.
    Don't let this intimidate you. It's not as difficult as you think
