Thread: frog problem
    frog problem
    so we just got a new place and the pool is in bad shape....the water is dark brown and there are several frogs living in the pool...good news is the filter and everything all works fine but it hasnt been turned on in awhile...i am worried about turning the filter on because of the frogs but i cant sweep them out because the pool is so brown...i am completly new at this any ideas?
    24k IG (plaster) Triton Sand Filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: frog problem
    You need to spend some time reading pool-school/ The frogs will be picked up by the skimmer. Empty the basket regularly and haul them a good ways from the pool to keep them from coming back.
    Re: frog problem
    ah...that was a helpful link thank you
