Thread: Goldline Pro Logic PS-4 + Pentair Intelliflo VS-3050
    Jul 2009
    Central Florida
    17
    Does anyone have experience with using the Goldline Pro Logic PS-4 control system to operate the Pentair Intelliflo VS-3050 pump? I'm trying to figure out if this controller can communicate directly with the variable speed pump and change speeds for different modes.
    10K IG plaster (9,500 pool + 500 spa)
    Cartridge filter rated 120GPM (Jacuzzi SherLok 120MB)
    Pentair Intelliflo VS3050
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Goldline Pro Logic PS-4 + Pentair Intelliflo VS-3050
    The Pro Logic will communicate directly with a TriStar VS but I think you may need the Pentair Intellicom interface kit to interface with the Intelliflo. There may be a way to work around that but it might void a warranty if you do.
    Mark
    Jul 2009
    Central Florida
    17
    Thanks! I figured there would be some kind of incredibly overpriced bit of equipment required for this to work, but neither manufacturer makes it easy to figure this stuff out.
    Is it correct to assume that without the "IntelliComm" interface the pump schedule can still be controlled, but it will default to the last speed it was set to? Or does it always start up at some fixed default speed setting?
    mas985's Avatar
    Pleasanton, CA
    11,741
    I believe I read somewhere that without the Intellicomm, the pump will turn on to the last setting used when shut off but you might want to read the manual on the Pentair site just to make sure. Also, any change to the setting will need to be done manually.
    Mark
