Thread: Question about pressure cleaner
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    I have just gotten around to getting my cleaner out of the box. Hayward Phantom pressure cleaner.
    I hooked up the hoses and plugged it into the return, checked the pressure with gauge that comes with it. Manual says it has to have 25psi. I'm getting that with my pump on low. Is that o.k.????? I guess I had it in my head that the main pump would have to be on high
    Haven't hooked the cleaner to the end yet. Will do that this afternoon when I get home.
    Thanks.
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    mas985's Avatar
    Pleasanton, CA
    11,741
    Re: Question about pressure cleaner
    The booster pump is probably compensating for the lower flow rate from the main pump on low speed. The cleaner doesn't need a lot of flow anyway just the pressure which is generated mostly by the booster pump. Probably the only effect you might see is that there will be significantly less flow rate through the normal returns when using the cleaner on low speed.
    Mark
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Thanks Mark. I'll check my other returns flow with it running when I get home. Good to know that I can run the cleaner on low speed. Just didn't want to mess something up.
    Lynn
