Thread: These nubers ok?
    TravisD's Avatar
    Jul 2009
    Tampa, FL
    142
    These nubers ok?
    I am at the final stage of my Baquacil conversion. If the FC holds tonight, then I will be done.
    Anyway, since my FC is low right now due to the sun, I decided to check the other levels.
    Here they are:
    TA = 120
    PH = 7.5
    CH = 180
    Are these levels ok?
    24' Round AGP | 13,600 Gallons | Waterway Cartridge Filter | Waterway 2 Speed Pump | K-2006 Test Kit
    100% Trouble Free Since The Baqua Conversion
    Butterfly's Avatar
    South Carolina
    10,045
    Re: These nubers ok?
    Yep. Look just fine.
    You're done SLAMing when:
    TravisD's Avatar
    Jul 2009
    Tampa, FL
    142
    Thanks Butterfly!
    22,543
    Yeah, and your numbers don't look bad either. Sorry, I couldn't help it!
