Page 1 of 3 123 LastLast
Results 1 to 20 of 42
Thread: Hawkeye's Baq Conversion
    hawkeye's Avatar
    davenport,iowa
    118
    i tested last night for overnight fc test, i got the fc level up to 16.ppm last night and this morning it dropped to 14ppm and cc was 0.4 ppm it only takes like 3 drops to get cc to change back over clear again does this sound right? and that 0871 reagent i use like 70 to 85 drops to test around this higher range?... so i am totally getting used to my new taylor 2006 test kit i like it alot but i had to get a 2oz bottle of 0871 any info would help thanks mike b
    18ft 52in deep doughboy 8000 gallons
    22 in sand filter
    1 1/2 pump
    tk-2006 test kit that rocks!
    12.5% chlorine
    aqua critter vac
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: my coversion is almost complete!
    Something doesn't sound right....
    What size water sample? With 10 ml sample, If the FC was 16, it would mean 32 drops. If you did 3 drops for the CC, your CC is 1.5.
    hawkeye's Avatar
    davenport,iowa
    118
    no i use the 25ml test line im putting in 2 scoops of the powder and it lights up dark pink i didnt get it clear until like i said 70 to 80 drops? i multiply the drops x .2 am i doing this right? i heard the 10 ml sample is less accurate?
    22 in sand filter
    1 1/2 pump
    12.5% chlorine
    aqua critter vac
    It sounds like you are doing well. With only a 2 ppm drop in FC overnight you are nearing the end of the conversion. Keep at it for another few days and you will be there.
    Doing the FC/CC test with the 10 ml sample size is less precise, but it is fine for what you are doing right now. For that matter, it is fine for nearly everything. There isn't much point in doing the test by 0.2s, when measuring FC levels up around 15, it takes extra time and uses up reagent.
    hawkeye's Avatar
    davenport,iowa
    118
    do i need i cya level to help hold for overnight fc test
    i am so close to being done with conversion water is super clear! im just waiting for the fc to hold overnight but i tested for cya and it didnt show any cya..is this normal during this conversion? will this convert without cya?then when i pass overnight tests do i change sand out a then put cya into new filter sand through skimmer to bring up cya level? thanks mike b
    22 in sand filter
    1 1/2 pump
    12.5% chlorine
    aqua critter vac
    You don't want there to be any CYA in the water until the next to last step in the conversion. You are almost ready to add CYA, but not quite yet.
    11,969
    Re: do i need i cya level to help hold for overnight fc test
    Quote Originally Posted by hawkeye
    When the FC holds overnight, you change out the sand.
    Then you add CYA to a sock, and set the sock in the skimmer, don't block the water flow, or tie it off in front of the return - wherever it will dissolve faster. Keep the pump running while the CYA dissolves. Wait a week before you test for it again, or you'll just waste reagent.
    Shock again until the CC is .5 or less for two consecutive nights, then your conversion is complete.
    hawkeye's Avatar
    davenport,iowa
    118
    thanks for the help i am changing out filter sand tonight i have passed all my overnight tests i had to wait until today because of the holiday...how much cya should i buy how much will i need to use and have on hand?
    22 in sand filter
    1 1/2 pump
    12.5% chlorine
    aqua critter vac
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    pool-school/recommended_levels
    www.thepoolcalculator.com
    you don't lose cya except to splash out and that sort of thing.
    hawkeye's Avatar
    davenport,iowa
    118
    ok i changed out my sand last night to find out that the drain plug on the bottom of sand filter all came off together and was stripped the cap was welded on i swear! haha... i had to go get a new plug today for $19.99! i got ripped off! frigin local pool store...so got new sand in today and i bought 2 bottles of 1.75 lb or .0794 cya....i read on forums that because of the baqua to chlorine i probaly dont have any cya at all anyway? so i figured from 0ppm to 40ppm? that i need a more than the 1 bottle? on pool calc. my pool is a 18ft round 52in deep 7700 gallon i think doughboy aboveground so weight wise i figure 41 oz? also can i add all of it to a sock and put in skimmer? what is a good starter amount? thanks mike b
    22 in sand filter
    1 1/2 pump
    12.5% chlorine
    aqua critter vac
    Round Rock, TX
    529
    When making a big chemical change, I typically use 2/3 of the recommended amount initially, then follow up with whatever is needed on a second dosing.
    dave
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    hawkeye's Avatar
    davenport,iowa
    118
    hello one quick question i am dissolving cya right now in skimmer, the fc got down to 1ppm today how high of fc should i get it up to? should i shock fc to 15ppm again for couple more days?
    22 in sand filter
    1 1/2 pump
    12.5% chlorine
    aqua critter vac
    You want to maintain the FC at 15 until you have CC at 0.5 or lower on two consecutive days.
    hawkeye's Avatar
    davenport,iowa
    118
    one day down one to go!!!!!!! i had cc test show 0.5 this morning so one more day to finish conversion what would i do after this is done start testing water to balance it?
    22 in sand filter
    1 1/2 pump
    12.5% chlorine
    aqua critter vac
    You are doing great!
    Yes, test and balance the water tomorrow.
    hawkeye's Avatar
    davenport,iowa
    118
    one quick question i about cya i put in sock in skimmer last night it is still dissolving and we had 2inchs rain today, my wife said the pool is overflowing out the skimmer,so water has to be pumped out so my question is what setting should i run filter so i dont lose cya in filter sand? vaccum to waste? drain it with that setting without backwashing cya out ? hope im making sense i dont want to waste it
    22 in sand filter
    1 1/2 pump
    12.5% chlorine
    aqua critter vac
    Yes, vacuum to waste, don't backwash.
    hawkeye's Avatar
    davenport,iowa
    118
    i shocked pool last night then tested for overnight fc &cc test and fc was 15ppm cc 0.5ppm and this morning it was 13ppm cc 0.5ppm does this sound right? i put 28 oz of cya in it yesterday and i was surprised that it lost 2ppm overnight i still have to put 13oz of cya yet i was going to wait a week test then add more.........water is crystal clear, little dirt bugs & stuff on bottom that needs vaccumed out...im just worried about fc dropping like that overnight.......
    22 in sand filter
    1 1/2 pump
    12.5% chlorine
    aqua critter vac
    hawkeye's Avatar
    davenport,iowa
    118
    heres a quick update on my pool numbers
    fc 12
    cc 0.5
    ph 7.5
    ta 140
    ch 134-140
    why am i losing so much at fc night? i was easy before i put cya in it we did have rain last night and last 2 days
    22 in sand filter
    1 1/2 pump
    12.5% chlorine
    aqua critter vac
  20. Back To Top    #20
    11,969
    Another small FC loss after adding CYA is annoying, but it isn't really surprising. You need to continue to maintain FC at 15 until your overnight loss is 1.0 or lower and CC is 0.5 or lower.
