Thread: crystal clear a little algae
    Island of Long, NY
    11
    Got my TF-100 great kit, water has been crystal clear. Arrived home after being away for 3 days and have a little visable algae. The water is very clear.
    FC-5.5
    CC-0.5
    CYA-90
    PH-7.5
    I put in enough bleach to bring FC up to 7 as per the pool calculator and CYA chart. Just wondering should I shock now, something is causing the algae? Or just make sure the FC stays at 7. Kids don't use the pool like they used to, to cold for the bride, and I just dive in and get out. It looks nice though
    thanx jimmy
    Jimmy
    22108 gal. ig, vinyl, 44 gpm sand filt, 1 1/2 hp pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: crystal clear a little algae
    For your CYA of 90, if you don't have a SWCG, you want to keep your chlorine around 10ppm. 7 is the minimum. I'd recommend raising it to shock level to get rid of the algae that is starting.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Can you describe the algae?
    Island of Long, NY
    11
    Yes it's the same green algae I always get, yesterday bottom of pool felt slimly till I brushed it. So according to the CYA chart the shock level should be 35, how long should it be kept there because the CC is already 0.5
    or till I have CC of 0.0 .... I vacuumed most of the algae, just some in the nooks that I'll brush after I shock.
    Thanx Jimmy
    Jimmy
    11,969
    You have to shock until the FC holds overnight, or you lose less then 1ppm. CC is .5 or less.
    Refer to Pool School for instructions on doing the Overnight Loss Test correctly.
    Island of Long, NY
    11
    Will do thanks
    Jimmy
