Thread: TA and PH adjustments
    Is it easier to adjust TA or PH? Both of mine are a little low.
    21ft round, 54 inch deep DoughBoy Desert Spring Above ground
    3/4 HP Dough Boy pump, Sand Filter
    Knoxville, TN
    GO VOLS
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: TA and PH adjustments
    What are they.
    When I took them the other day the TA I believe was 100 and PH was 7.4, but I am also finishing up my conversion so not sure how accurate they are, just wanted to check in case my lovely pool store tells me different.
    Knoxville, TN
    GO VOLS
    11,969
    If they are still 100 and 7.4 I wouldn't touch them. They are fine, and if the PH is really a little lower, it can wait till your conversion is complete to be adjusted.
