Thread: New tub, first numbers
    Laenini's Avatar
    Aug 2008
    Brooklyn Center, MN
    90
    The new tub arrived and its up and running. I just checked my first set of numbers and here they are:
    pH = 7.8
    FC = 1.5
    CC = 0.5
    TC = 2.0
    TA = 260
    CH = 320
    CYA = 25
    Now, before any of you tell me that I am crazy and that I need to go check those numbers again, I should explain that we used 1/2 fresh tap water and 1/2 water from my pool to fill the tub, so that is why there is already CYA and chlorine showing up.
    I did a quick check of my pool water and its readings tonight are:
    FC = 6.0
    CC = 0
    So, my first goal is to adjust the TA, correct? Its a 500 gal tub so I am going to add a total of 5 oz of MA (diluted and as 2.5 oz additions) and then turn all the jets on. Then I recheck in 30 min, right?
    Any thoughts too on why my pool tests negative for CC but I'm finding them right away in the tub? Should I shock just to be safe?
    Leanne
    Pool: 24' round by 48" deep AGP
    Waterway 1HP-2 speed pump, H100 Heater, sand filter, skimmer, using BBB (love it!)
    Hot tub: 2008 CalSpas, 8x8, 8 seats, 60+ jets, ozonator
    3 step bromine sanitation
    Jan 2009
    Cupertino, CA
    1,966
    Re: New tub, first numbers
    You're on the right track for lowering TA. Because of the high CH and the high temp in the spa, you'll want to keep pH and TA low-ish in the long run.
    I always get some CC in the spa and rarely in the pool. I wouldn't worry about it as long as it's 0.5 or less.
    --paulr
    BBB "Intermediate Swimmer"
    Mar 2007
    San Rafael, CA USA
    12,082
    And I would especially not worry about the CC if you see it high after a soak -- that is to be expected. It's the CC level before the next soak that is relevant and as Paul says if it's <= 0.5 ppm I wouldn't worry about it.
