Thread: hose pops off filter
    every time I run my filter the hoses keep popping off. I have used 2 hose clamps on each connection and now have even tried to wrap the connectors with thread tape. nothing's working. Help, anyone
    18x36 - 20000gal - vinyl - chlorine - cartridge - heated
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    902
    Re: hose pops off filter
    Quote Originally Posted by ericjw
    what kind of pool and equipment do you have...that would help to answer the question. Pictures would help too if you have any of the hose and the connection. My first guess would be that you are not tightening the clamps down tight enough...They must be very tight...Under pressure even slightly loose the clamps would blow off...happened to me when I opened pool this spring...I went out to check on pump and I was blowing water in my yard from the filter...They gotta be tight. The other thing could be that because of extreme heat the hose may expand and come off if the clamps are not tight enough...but just guesses...Get radiator type hose clamps that are made for car engines...tighten the screw down as tight as you can get it. Should stay on after that.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
