Thread: Turn Cell Off?
    bbqbrew's Avatar
    Flower Mound, Texas
    14
    Turn Cell Off?
    Should I turn my SWG "off" when adding chemicals like CYA to my pool? I usually don't for acid or baking soda...but since CYA takes so long to dissolve I was wondering if it might damage the cell in some way.
    Master KomodoKamado griller & beer maker!!
    12,000 gallon in-ground, pebble-tec, SWG pool w/spa
    mas985's Avatar
    Pleasanton, CA
    11,742
    Re: Turn Cell Off?
    No, you don't have to turn off the SWG when adding chemicals although the only chemical you should add to the skimmer basket is CYA.
    Mark
