Thread: Using Solar Button on Jandy RS4 Controller
    I have a Jandy RS4 controller with all 4 relays in use (filter pump, 2-stage pump, jet pump, and light). I'm trying to add a waterfall pump that I can turn on and off independently. I saw somewhere that the solar circuit can be used to control an auxilliary circuit. Has anyone done this or have experience with this contoller. Is it possible to re-label the solar button in the Onetouch to say 'Waterfall'? Any help will be greatly appreciated.
    AG pool 18 x 52 (~8300 gallons)
    Hayward Sand Filter
    Hayward 1.5 hp pump
    pictures of our pool and equipment
    Re: Using Solar Button on Jandy RS4 Controller
    I'm not sure about this, but I think it is only the solar JVA (valve control - 3 pin socket) that can be reassigned if you don't have solar. I don't think you can reassign the solar booster pump relay (2 pin socket) to operate a waterfall pump relay. I have solar so I have not tried reassigning anything.
