Thread: Pentair Variable speed stuck on #4 and won't prime
    Another day another problem. I have muddy water, then the strainer clogged and now my pump only starts on #4-you can't manually change the speed now. The pump will not shut off manually (breaker used) and prime as well and the red alarm is flashing. Any suggestions would be appreciated. Help!
    Susan
    16'x48" Intex Ultra Frame Pool, Krystal Klear pump #635 (1,500 gallons)
    "just getting it out of the box"
    Re: Pentair Variable speed stuck on #4 and won't prime
    Finally got it to prime and it is running. Will not shut off manually and still cannot change speeds. I have a call into pentair. If anyone has had this happen please post! Thanks!
    Susan
    It sounds like there is some kind of hardware problem with the control panel. Pentair service is the right thing to try.
