Thread: cyanuric acid level
    cyanuric acid level
    Hello, I was in the pool store over the weekend and I heard one of the employees telling a customer that cyanuric acid never changes once it is in the water. I am relatively new to pools but I have browsed through many of the posts here on this forum and the posts on poolforum.com. I have concluded that cyanuric acid does 'burn off' over time. Is this correct? Thanks in advance.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    CYA seldom goes away on its own. Dilution by rainwater tends to lower it, but it doesn't just go away.
    I believe some pools see a drop in CYA over the winter, and the proposed cause is organics in the water that consume the CYA, since the pool is not being sanitized. But for the summer, most do not see a drop in CYA unless they have to backwash to waste, have a leak, or drain some water.
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
