Results 1 to 10 of 10
Thread: A Cover for the SOLAR POOL COVER?
    Okay - so I've built my own SOLAR COVER reel and actually have a place on the side of the fence to STORE the rolled up cover but it's just as easy to leave the 'reeled-up' cover on the pool. This means it's exposed in the sun - like when it's ON the pool.
    So, I've seen and heard about covers that you put OVER your SOLAR COVERS - what's up with that? Are they absolutely necessary? What's the harm if you don't COVER the COVER?
    dpool
    9x17 AG Vinyl "SPLASHER" w/outside struts (7/04), thru the wall skimmer & return, C900 Hayward Cartridge Filter (3/08), 1 hp Hayward Power-Flo II pump (4/09), Wanda Whale auto cleaner (3/07), new Wanda shoes (6/09), VinylWorks A Frame Step Ladder Entry System w/Gate (5/06), 5-1gal gravel-filled jugs hung w/ zip ties under steps to stop steps from floating, 1-3" TAB FLOAT under stairs (empty), More noodles, floats, and toys than allowed in any 9x17 sized pool!
    Aug 2007
    Northeastern Ohio
    178
    Re: A Cover for the SOLAR POOL COVER?
    If the cover is rolled up and has the sun beating on it during the day, the heat can (at minimum) make the bubbles on the bottom of the cover pop, and at worst, melt the cover slightly.
    My cover is quite large and I usually move it into the shade during the day. I realize that not everyone has shade, of course.
    If you don't want to spend the money on a cover for the cover, you could always throw an old, light colored bed sheet over it.
    ~30000 GAL In-Ground 26'x50' Kidney Shaped Pool
    Hayward EC-75 DE Filter w/1.5HP Hayward SuperPump
    daily user of JasonLion's Poolcalculator
    (12) 2x10 SunGrabber Solar Panels...now if only there was some sun to shine on them!
    Mar 2007
    Morris, IL
    477
    What about a tarp?
    steve
    Above Ground / 18' Round / Vinyl Liner / Sand Filter / 100K Gas Heater / Salt Added / No Nature2
    kilika2003's Avatar
    May 2009
    Toronto, ON
    48
    I read a post recently about someone who made one with vinyl and velcro...
    http://www.troublefreepool.com/hi-fr...er-t15249.html
    15' x 24' x 52" Buttressfree Concorde (Atlantic) ABG installed 2007, Hayward Sand Filter, Hayward 1 speed Pump, Royal Entrance Steps, Clear Solar Blanket, New Deck, and maybe soon a heater.
    unless you have one of the high tech black/silver solar covers, there's really no need - we are in the scorching sun every day - there is no shade near the pool, I've never had issues with my cover and the first one (a 3r) lasted 6 years and is only breaking down because th last 2 wintrs I left it on the roller and every spring the birds would try and build nests in the ends and peck at it.
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    902
    Quote Originally Posted by matt4x4
    I have had mine out in the yard for three weeks now...I put on once since then...There has been no issue with melting or anything...but then it hasn't been above 85 in three weeks either. But it has been sunny...I would think in extreme temps it might be bad...but it really is up to you...They tell you cover with something white that reflects the sun. Haven't done that in two years.
    Beave
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    Shelley N's Avatar
    Denver, Colorado
    199
    My husband and I have been wondering about this since spring when we had to replace our cover. Has anyone actually known of one that melted or popped, or is it an old wives' tale?
    We took the best care of ours we possibly could have, keeping it in the shade 99.7% of the time and it only lasted 3 summers. I think it was an 8ml. We're thinking about rigging up some type of roller, but it would be in the sun all day, being attached to the side of the pool. I think we could cover it with a white sheet or something most of the time, unless it blew off in high winds.
    I wonder which is harder on it, being in the sun, or being in bleach year after year.
    Shelley
    Denver, CO
    Jun 2007
    Poughquag, NY
    217
    Every "solar" cover that I have bought (I'm on my third) came with a white sheet of thin plastic that is supposed to be used to cover the cover when it is exposed to sun. I didn't use it on my first 2, one lasted about 3 seasons, the next only a season and a half. I'm trying it on this third one. You just lay it over and secure it (I use the cover pull lines and just wrap it around a few times.
    It definitely seems to keep the cover cooler.
    20 x 40 vinyl IG. SWG. Solar. Ikeric VS pump.
    Thanks for the info - I'm for the 'old sheet' solution - now ... to find one I'm willing to sacrifice to the POOL.
    I haven't completely finished the SOLAR COVER REEL yet. Still need to figure how to pull it across the pool evenly and 'effortlessly' without it going underwater on the way - I see where having an ABOVE GROUND POOL causes a DISADVANTAGE in this ONE area.
    Need to think about this some more ... .
    dpool
    reindeerboy's Avatar
    May 2008
    Jamestown, ND
    519
    You can find a sheet of plastic at any harware store. Just measure the length and then they can usually cut it to the size you want. I just bought mine at menards, its called landscapping plastice, and it works great. I then used some bungee cord and just wrap it around the reel and it holds it perfectly. I put a plastic hook on the end of it it. I bought a 100 foot of the bungee cord and just cut it to size. Should last me for years.
    My cover last year did melt a bit and the bubbles did snap so I always cover it up as I have no shade.
    Works Great! Hope that helps.
    Chad R.
    POOL SIZE: 16 x 32' Vinyl lined pool. 22,000 gallons. 8' deep. 2009 Hayward 1.5 HP Super Pump. Hayward S310S 30" 500 lb Sand filter. 1 skimmer and 2 returns. Solar Blanket.
    Pics of my pool: http://s307.photobucket.com/albums/nn312/reindeerboy/
