Results 1 to 8 of 8
Thread: Link to Posted Information
    Is there a way to do a search on a particular topic/words and then be able to read the post on that topic? Yesterday I thought I generated a post on sodium bicarbonate. Can't find it today. Maybe I had a senior moment and did not actually post the comment only typed it.
    In-ground concrete/vinyl 21000 g, sand filter, Pentair 1 HP and 50 gpm. Pentair Legend in-pool cleaner, Nature 2 system (cartridge removed).
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Link to Posted Information
    Google Search, bottom left corner.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    I've got to be one of the least computer literate members here ,,, so let me tell you what I do Since I can't always rely on the search function - I just go to "View your posts" in the upper right hand corner right below the POOL SCHOOL button to check on anything I've participated in
    Not sure how I managed to do it but when I log in, below my name and non-avitar is the option to view new posts or my posts - I always go to view new posts and can see every post that has happened since I logged off (to be quite honest, I've only checked the entire forum topics a couple times - I don't have to the way I'm set up )
    As for the 'senior moment', I've had a few of them - what I think I did wrong was to confuse previewing the post with submitting it and then just leaving the post. My wife has taught me how to open another window and check if the post actually posted - of course I often forget to do that
    Try to keep an eye on whether you're submitting or just previewing and remember to look for the page that says 'Your message has been posted successfully' before leaving the thread :P
    Luv& Luk
    -Ted
    11,969
    Good suggestion Ted!
    Mar 2007
    4,160
    Ann, sometimes it actually helps not to know how to use a computer
    I don't assume others are as bad as I am, but if a 'non computer' person like me can post here, sometimes I'm more helpful than those who actually know what they're doing
    Luv& Luk
    -Ted
    Doing the Google search does not get the results I want. I'm looking for my previous posts and they would not be on Google. However, the "View your posts" did show me that I really did post the comment on sodium bicarbonate.
    Thanks everyone for the assistance.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    the google search in the bottom left hand corner will work, you just have to put in the right information and possibly go through pages of results to find it. that google search searches only this site.
    Butterfly's Avatar
    South Carolina
    10,045
    You can see a list of all your posts in descending chronological order thru the profile search:
    On the Home Page click on your username either under the "Who is online" (left side ) or the "User Menu" (right side), or,
    from within any of your posts, click the "profile" button (bottom left, next to PM).
    That will take you to "viewing (your) profile" where you can select "Search User's posts".
    Hope this helps.
    You're done SLAMing when:
