Results 1 to 7 of 7
Thread: Is fc too low?
    May 2009
    Trenton NJ
    497
    Is fc too low?
    I been running my pump for 12 hours per day and here are my numbers:
    fc-2.5
    cc-0
    ph-7.9
    ta-80
    ch-230
    cya-85
    Is my fc level too low with a cya of 85? I have a swg and the pool is in direct sun all day.
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
    30,403
    Re: Is fc too low?
    How does your water look?
    If it's crystal clear with absolutely no sign of algae or cloudiness, you FC is most likely okay.
    Generally, speaking, that's a little lower than most pools should be, tho. (Check the FC/CYA relationship Chart up in Pool School)
    Your pump run time is certainly adequate so perhaps you could boost the percentage on your SWG if you decide to bring FC up a little.
    May 2009
    Trenton NJ
    497
    Re: Is fc too low?
    The odd thing is my swg is at max output. The pool water is clear but would be happy if fc was higher. Would I have too shock and extend pump time to maintain a higher level?
    May 2009
    Trenton NJ
    497
    Re: Is fc too low?
    Oh, one more thing my salt level is 4000 ppm which is what manufact. recommends.
    30,403
    Re: Is fc too low?
    Hmm, that may tell us you have some invisible organics(algae) starting in there?
    Do you know and understand the Overnight FC Loss Test? It's in Pool School if you're not familiar.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Is fc too low?
    seems low to me. are you using that duoclear system? introduces cya I believe which you don't want more of. I wouuld do the overnight fc loss test if you have a fas-dpd test.
    pool-school/overnight_fc_test
    May 2009
    Trenton NJ
    497
    Re: Is fc too low?
    I will try the overnight test tonight.
