Thread: How much bleach ??
    Fayetteville, Arkansas
    220
    How much bleach ??
    Do you use in order to keep your FC levels where you want them to be?
    I'm losing about 2.5 ppm per day in FC with my CYA at 40, CC is 0, CA at 180,
    TA at 100 and Ph at 7.4 The only thing I'm using is 6% bleach and no shocking has
    been required to date. I'm not using any kind of pucks in the skimmers, just around 190 oz.
    of bleach every other day. The pool has gotten full sun every day lately.
    The water is sparkling clear and couldn't be happier.
    Just wondering if this loss rate is about right.
    Hope everyone's pool is clear and cool ...
    20x40 30,000 gal IG Liner, Pentair II Sand
    30,419
    That's about dead on the money compared to my full-sun pool.
    Jun 2007
    Charleston, SC
    151
    I use about half a gallon a day in an 8000 gallon AG pool. It gets full sun all day.
    18' Round ABG (8000 gallon)
    Hayward X-Stream Cartridge Filter
    1.5hp Hayward PowerFlo Matrix Pump
    80 sq. ft. solar panels
    Goldline automated solar controller
    Mar 2007
    San Rafael, CA USA
    12,082
    A pool in full sun all day typically loses up to half the starting (morning) FC level, though it's usually a bit less. Some people have found that having a higher CYA level helps reduce the loss even when using a proportionately higher starting FC level, but this is a difficult change to reverse (if it doesn't work for you) as only dilution of water will reduce CYA levels. Also, shocking at higher CYA levels requires a lot more chlorine (if one ever needs to shock). Nevertheless, some people run their non-SWG pools at higher CYA (60-70 ppm) and are happy with it.
    Jun 2007
    Charleston, SC
    151
    Im actually trying to bring mine up to 70-75ppm as I type this.
