Thread: Best location for lights
    Vero Beach, FL
    462
    I am having 2 Savi Melody LED lights installed in my pool that is currently being built. The pool is roman shapped, with the side 21 feet long and an extra 2 feet on each end for the rounded bit. So the two LEDs will be placed somewhere in the 21 foot wall. What would be the best spacing option? Obviously, we want them spaced equally separated from the center of the 21 feet - but I just don't know by how much. If I place them so that they cut the pool length in 3 equal spaces (ie. 8.3 feet apart), won't the light in the middle be brighter than the edges? Am I overthinking this?
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Best location for lights
    Welcome to TFP!!
    Can you give us a diagram of the step layout and the pool? You definitely want light on the stairs!
    What we often do is have a light directly across from the stairs and one in the center of the deep end wall
    Luv& Luk
    -Ted
    Vero Beach, FL
    462
    That's exactly where the pool builder put them. One closer to the shallow end to illuminte the steps, and one in the deep end. They seemed too far apart at first glance, but I think its going to work OK.
    See any problems?
    Solar heat
    Mar 2007
    4,160
    That's pretty much were we'd put them, as long as the spa faces the house! It seems that having the lights face the house can be annoying to many folks - but on the other hand... there are times you don't want the lights facing the spa
    Please keep us posted as to the progress of the pool
    Luv& Luk
    -Ted
    Vero Beach, FL
    462
    Thanks for the help. The 2 pool lights face away from the house and main patio area. The spa light does shine that way. However, I will have a separate switch for the pool and spa lights. I'm going cheap and just having them hard wired (no wireless control center), but I am going to get a couple of the wireless wall switches and use them for remote control of the lights.
    Solar heat
    The way that I would do (not that I'm an expret or anything) it is to make the distance in between the two lights twice the disance from the light to the edge. For instance if you had a 20' length, the first light would be 5' from the wall, then 10' in between, and another 5' to the other wall. This way you will have similar lighting on the end and in the middle. So for a 21' wall Id go 5' 4" from each wall. You can think of the light as having a 5'4" radius, see how the radius would just touch the ends and the middle with no overlap?
    15,000 gallon gunite pool, grey plaster with 8' raised spa
    Jandy PlusHP Pump 2 HP Dual Speed
    Sta-Rite 450 Sq. ft. Cartridge Filter
    Cleva-Chlor RP40HD
    Raypak 400k btu heater
    Jandy Aqualink RS-8 One Touch
    Savi Melody 12v LED lights
