Results 1 to 10 of 10
Thread: Please identify
    spiazza's Avatar
    Berkeley Heights, NJ
    76
    Please identify
    I am trying to identify these discolorations in the deep end of my pool. Algae or stains? They are brown discolorations that don't move when brushed, appear to be slowly spreading (in my opinion), hard to see when the sun is shining on the water.
    I was advised they could be organic and go away with time. I haven't seen them fade yet and the pool has had 8+ppm of FC in it for several weeks.
    CC in less then .5 and FC overnight test passed.
    The stains don't translate well on camera but here are some samples anyway. The stain is browner and more pronounced in person.
    My Pool Stats
    IG Pool - 21,000 Gallon - Vinyl Liner
    Hayward 1.5HP Super Pump EE; Hayward DE Filter; Goldline SWG
    32' x 16', 8' deep at the deep end, about 3' shallow end
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Please identify
    OMG!!! You've got black circles on the floor of your pool (wait a minute - you drew those in to show the problem areas ) :P
    I'd be willing to go with organic unless someone applied a little green stain to your MD cover. I'm afraid you have something trying (fairly successfully ) to grow in the deep end. Other than the MD, is there any circulation going on down there - like a return pointed into the bottom of the hopper? One of the members here (actually he posted it on PF) Matt4X4, had some posts about a persistent algae which I dubbed "Matt's Mud" or "4X4 algae" found here on Pool Form. As I recall, treat it as if it were mustard or black algae and it will eventually leave the pool
    I know I've seen Matt here of late (HI Matt ), perhaps he'll see this and have an update on the stuff
    Luv& Luk
    -Ted
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Please identify
    Organic stains usually fade with proper FC levels, mine did. What's your CYA level?
    spiazza's Avatar
    76
    Re: Please identify
    CYA level is 70. I'm hoping they fade over time. I've been keeping FC at 8ppm. I don't think algae level shocking is going to do much. It might just be a waste of time and $.
    My Pool Stats
    11,969
    Re: Please identify
    I'd say it took about 2 months for mine to vanish completely. It was a very gradual fading.
    Re: Please identify
    You could try placing a Vitamin C tablet on a stained area for 30 seconds and see what happens. If they are iron stains, the area where you applied the Vitamin C tablet will get significantly lighter or clear up completely.
    spiazza's Avatar
    76
    Re: Please identify
    I wouldn't mind trying the vitamin C test but how to suggest I place a test tablet to the bottom of the 8' deep end?
    My Pool Stats
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Please identify
    just put it there. it should stay somewhat in place. your areas are so big that it should stay on a spot even if it moves slightly when you swim back to the surface. or you can swim down and hold it. even if it's only 20-25 seconds it should make some kind of change I would think (if it was going to at all). or you could get maybe a 3/4" pvc pipe about 10' long. put it on the spot and drop the tablet down it. if you didn't want to retrieve it you could probably brush it around. they dissolve pretty quickly.
    Sallie's Avatar
    May 2008
    Columbia, SC
    103
    Re: Please identify
    OR you can drop it into the water near where one of the stains is and then when it gets to the bottom, push it to where you want it with your brush. That's what I did, didn't have to get in the water at all.
    Sallie
    25 K gal., vinyl IG, Hayward 3/4 hp pump, Hayward Pro Series S-220T 18" sand filter, full sun all day, no main drain, Taylor K-2006C and K-1766 test kits, Circupool RJ45 SWG - Columbia, SC
    spiazza's Avatar
    76
    Re: Please identify
    Thanks for the suggestions. I will try them and let you know.
    My Pool Stats
