Results 1 to 15 of 15
Thread: High Acid Demand...Low TA??!
    Jun 2007
    Spring,Tx
    55
    Here's the Numbers:
    FC 2.0
    TC 2.0
    CC 0.0
    PH 6.8 (I just added acid this AM)
    Hardness 190ppm
    TA 40ppm (I know this is the culprit for the acid demand)
    CYA 65ppm (alittle low)
    no metals....
    I guess my big question is, should I go with the 20 mule borax to raise my TA or go with 15 pounds of alkalinity control? I read the thread on using borax to raise the TA and like what people say about the water.. That being said my water is amazingly clear at the moment.
    Warehouse pools and raise my TA and soften the water for about 40 bucks worth of chems.. I figure the borax and close to 4 gallons of acid will cost me more than that just to raise the TA.. It's not all about the $$, I'd love some opinions..
    TIA.
    Dave
    16k I.G. Gunite, SWCG, 1.5hp Hayward Pump, .75hp Booster Pump w/ Hayward Phantom Cleaner,Hayward C5025, swimclear cartridge filter, 400k Hayward heater.
    Jun 2007
    Spring,Tx
    55
    Re: High Acid Demand...Low TA??!
    Ok so after further reading I now realize that adding borax will not raise my TA. So I have to solve that problem first. I have a feeling the amount of aeriation from my sprayers is the cause of a low TA? The water temp has been high so I've been running my sprayers mounted under the coping in the evening to lower the temp..
    30,420
    If I understand your post, you can raise your TA with baking soda.....it will have marginal effect on your pH.
    Sorry to answer a question that wasn't asked but your FC is too low. Algae loves low FC.
    Jun 2007
    Spring,Tx
    55
    Tell me more Dave? How much for a 16k pool? I'll browse the forum and look for myself but if you know off hand that would save me the trouble.
    Mar 2009
    Glendora, California
    169
    edit: Sorry stakeman, misread your post about aeration. It sounds like yes the end result of your aeration is low TA........
    Aeration will raise your PH not your TA, adding acid lowers your PH AND TA, aeration continues and PH rises again (TA does not go up), you add acid again, PH AND TA go down, aeration continues and PH goes up again (TA does not go up) rinse and repeat. Hope I didn't confuse you.
    18k Inground Plaster pool / TriStar Variable Speed Pump and Controller
    48sq ft Hayward DE filter/ Swim pure Plus 40k cell / Kreepy Krauly
    Solaxx Ph-Tek
    Jun 2007
    Spring,Tx
    55
    I've added ALOT of acid this summer because of the sprayers raising the PH. Which dropped my TA...so is there a pro vs con using the baking soda vs Alk control sold at the pool store? The calculater has me adding around 10 pounds of baking soda...
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    are you using an algaecide or something else to keep algae away?
    here are the charts and more info:
    pool-school/
    pool-school/chlorine_cya_chart_shock
    pool-school/water_balance_saltwater_generator
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Quote Originally Posted by stakeman
    it depends on how much you want to pay for baking soda. I bet the pool store charges more for theirs since it comes with a cool name. and maybe a pail. does it come in a pail? I always find it hard to say no to anything that comes in a cool pail with a handle.
    Jun 2007
    Spring,Tx
    55
    Quote Originally Posted by reebok
    My wife shops for groceries so I honestly can't say how much 10 pounds of baking soda costs, and I don't watch the price is right enough to know. I didnt think 15 pounds of the pool store Alk control was that expensive. I'll bet the difference in price isn't more than a couple of bucks, but we'll see. ...The pros-vs-cons I was asking about really didn't refer to price, but thanks for your reply!
    Guest
    Akalinity increaser from the pool store is sodium bicarbonate AKA sodium hydrogen carbonate.
    Baking soda is sodium bicarbonate AKA sodium hydrogen carbonate.
    They are one and the same, the only difference is the price and the package and possibly the purity. The stuff from the grocery store is going to be purer since it is a food and drug grade AND it will cost you a LOT less.
    Your call.
    Lowes sells a 4 lb jar of Alkainity increaer for $17.98
    http://www.lowes.com/lowes/lkn?action=p ... 0Increaser
    A 12 lb bag of Arm & Hammer is anywhere from a low of aobut $5 at Costco to under $7 at Walmart to this high price on the 'net
    http://www.mightyox.com/ARM-HAMMER-Baki ... ce=froogle
    You can also buy a 4 lb box of Arm and Hammer baking soda at the grocery for under $4 just about everywhere.
    Do the math.
    Jun 2007
    Spring,Tx
    55
    Ok so I added the baking soda for under 10 bucks. That saved me about 18.00! I'll recheck the TA tomorrow. I guess having a SWG I'll just be a BB guy.
    I haven't read anything comparing the grades of sodium bicarbonate. Unless someone has a good reason not to use sodium bicarbonate purchased as farm grade from the county co-op I would recommend that as a source. Here in Alabama a 50 # bag cost about $9 plus tax. The swimming pool doesn't know the difference between the high price stuff or the low price stuff.
    In-ground concrete/vinyl 21000 g, sand filter, Pentair 1 HP and 50 gpm. Pentair Legend in-pool cleaner, Nature 2 system (cartridge removed).
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    borates have nothing to do with your chlorine delivery system. I highly recommend them for the feel of the water alone, much less their other good properties. glad you were able to save some $$ ;)
    I think he meant leave out 1 B for the bleach since he has a SWG
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    heh, doh
