Thread: Hey chemistry experts - chem geek et al...
    no-mas's Avatar
    Jun 2008
    FL
    405
    When I took college inorganic chemistry, one of my instructors once did one of the coolest experiments - which he called a "freshman alarm clock" because it was silent, and would have no effect on one who is asleep....
    Anyway, he added his solutions to a large beaker on a magnetic stirrer, and several seconds after adding the last one, the solution instantly turned from clear to black. Obviously it made an impression on me, as I remember the demonstration, but not what he was trying to teach
    My question, however, is have any of you seen this and can it be duplicated by a home mad scientist? I've searched the net and youtube, but obviously can't remember the right terms to search....
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Montreal Canada
    326
    Re: Hey chemistry experts - chem geek et al...
    Quote Originally Posted by no-mas
    The Briggs-Rauscher Reaction here:
    http://www.youtube.com/watch?v=NZ6Vr0ANGZg
    "oscillating chemical reactions" is what you want to look for.
    no-mas's Avatar
    Jun 2008
    FL
    405
    I only remember it happening it once, instead of oscillating, but this must be it. Thanks so much!!
    AV8TOR's Avatar
    Dec 2008
    Fort Worth TX
    211
    Interesting find and I thought for a minute that I had found what I have been looking for too. I seem to remember an experiment that was very similar although it had one abrupt color change from clear to black in like 20 seconds after mixing. It went like having two pictures of clear liquid and then you start by pouring the complete contents of one into the other followed by pouring from one container to the other. If you time it right the color will change exactly while pouring. Anyone know that one? I believe a starch solution was in one container but I do not remember what was in the other.
    16,000 gal IG Double Roman Plaster Pool (16yrs - plaster redone 2014)
    Pentair FNS-48 DE filter with WhisperFlo 2HP single speed pump
    Polaris 280 robot
    BBB all the way and tested with a TF100 kit
    Pool Calc user
    Jul 2007
    Suwanee, GA
    528
    The guy holding the camera in the youtube video must have been nervous as ****. Waiting for it to explode perhaps.
    Gary
    21k gal SW, IG Gunite PebbleSheen, 1HP Jandy, Jandy 340 filter, Polaris 280, 17' fiberglass slide w/ 2HP pump.
