If the tabs are trichlor, stop using them.
Refer to the CYA chart for the appropriate shock level. You are done shocking when:
You lose 1ppm or less of FC overnight;
your cc is .5 or less.
Since you had a 6ppm loss overnight, you need to keep it at shock level. Hourly testing and bleach additions will speed up the process. Allowing the FC to drop down in between prolongs the process.
Make sure you are doing the overnight test correctly - read the instructions in pool school.
