Results 1 to 9 of 9
Thread: vac question
    vac question
    my vac goes thru my skimmer. do i need to remove the skimmer sock before i vacuum?
    24 ft. 52 in. deep above ground
    hayward sand filter
    new pool owner/new bbb believer
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: vac question
    with my vac you have to take the basket out and plug the vac hose into the pipe at the bottom of the skimmer. is that how yours is?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: vac question
    I would. If the sock clogs, it can damage the skimmer basket.
    Re: vac question
    i have to put plate adapter plate in top of skimmer then attach vac to adapter plate. the skimmer sock does get clogged. do i have to take basket out to vac?
    hayward sand filter
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: vac question
    ok sorry, totally different. pay no attention to anything I've typed.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: vac question
    Take the sock off, leave the basket, attach the plate. Vacume, replace sock.
    SW Indiana
    9,199
    Re: vac question
    Quote Originally Posted by reebok
    If I were you, I'd get a vac plate so you can still use the basket. Good protection against clogged pipes.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: vac question
    I don't vacuum ;)
    (see sig)
    but I did learn my new thing for the day. never heard of those before.
    Re: vac question
    thanks for info. starting to get control of my pool.
    hayward sand filter
