Results 1 to 7 of 7
Thread: Can The Pro's Here Check My Numbers Please....
    Jul 2008
    Denver, Colorado
    98
    I think I've cracked this pool 'lark' using the BBB method.
    Can anybody give me advice on what's below but I think it's good?
    FC-6.0
    CC-0
    TC-6.0
    pH-7.2
    T/A-100
    CH-180 (this goes between 180-190)
    CYA-50
    Temp-84
    What do you think?
    thanks - back to the pool
    25k Inground Vinyl - 3ft to 10ft, Tagelus TA-60 Sand, Minimax 400 Heater, Save T3 autocover.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Can The Pro's Here Check My Numbers Please....
    Ain't broke...
    If you want to "tweak" it, the PH could go up a tad to 7.4, but it probably will anyway, slowly.
    You could, if you want, point your return up to break the surface and create some aeration to raise it a little...
    Great job!
    Butterfly's Avatar
    South Carolina
    10,045
    Overall, great job
    If you're starting the day with a FC of 6, then by evening you will be close to (or below) your minimum FC if you lose 2 FC or more daily.
    You're done SLAMing when:
    30,415
    DB,
    How does your water look?
    Jul 2008
    Denver, Colorado
    98
    Water looks great. The FC was at 6 as i had just put bleach in that morning so it does drop down to 4 or 3 through the day....
    From my understanding, sparkly blue water is a sign you are on the right tracks?
    cheers all - the missus just gets worried seeing me dump Clorox in the pool so I thought I'd make this thread to prove everything is okay...
    danny
    30,415
    One of the real drawbacks to BBB is the funny looks you get from everyone who doesn't understand it. The checkout ladyat Walmart I know is seriously considering calling security every time I go thru with 15 jugs of clorox.
    The best ones are at the parties when someone asks, "How do you keep your water so sparkling"?
    "Clorox"
    "Hmmm, Clorox, that's very nice. So, it was sure hot today, huh?"
    Casey's Avatar
    SW PA
    10,438
    Last comment I got was...
    You cleaning alot?
    Um, yeah right!
