Thread: Intermatic T101 seems to have died?
    Aug 2007
    Northeastern Ohio
    I added an Intermatic T101 timer to my pump a little over a year ago. I has worked great, until yesterday I noticed that my pump was running later than it should have. We had two quick power outages the day before, so I thought the clock might have just been off. I reset the time and when I checked on it a few hours later, it hadn't advanced at all.
    How common is it for the clock motor on one of these to quit working? Is there anything I can do to fix it?
    ~30000 GAL In-Ground 26'x50' Kidney Shaped Pool
    Hayward EC-75 DE Filter w/1.5HP Hayward SuperPump
    daily user of JasonLion's Poolcalculator
    (12) 2x10 SunGrabber Solar if only there was some sun to shine on them!
    JohnnyT's Avatar
    Jul 2009
    Rochester, IN
    Re: Intermatic T101 seems to have died?
    Hey robrinker,
    If your clock motor isn't running most likely it has failed. I've had the same thing happen with two of my pool timers. In the first one the clock motor had burned out and the second one developed a short. Barring a loose connection, I don't know of anything you can do except replace. The cost of repair verses the cost of replace is, most of the time, about the same. It sounds like you may have had a power surge that took your clock motor out. In any event good luck.
    12K, 21' Round AG, 52" Deep, Vinyl
    Hayward EC 30-DE filter - 1 hp Hayward Power Flow LX pump, 40 GPM
    Hayward AquaBug Pool Cleaner
    You must give some time to your fellow men. Even if it's a little thing, do something for others - something for which you get no pay but the privilege of doing it.
    Albert Schweitzer
    pool4me's Avatar
    Sep 2008
    Bucks County, PA
    Intermatic sells the clock portion / gears separate. Usually available at Home Depot etc. Around here, the T103 that I just bought was something like $49 and the replacement clock timer was something like $26 or $30 or something like that.
    I've even seen them brand new on ebay. They just pop right into the case. Might be an option depending on what price you can find the timer at.
    33'x15' x 52" Aqualeader
    Gallons ? - (I use appx 13,500 to calculate "stuff")
    33 x 15 x 4.3 x 5.9 = 12,558. or . . The Pool Calculator = 14,400
    Hayward S-166T 100Lb Sand Filter - Hayward Power-Flo LX 1HP Pump
    Intex S.W.G.
