Thread: muriatic acid
    muriatic acid
    How long before we can swim after adding acid
    30,000 Gal in ground w/spa and spill-over, Jandy Laars LX Heater/Jandy RS-6 Automation System with spa side switch
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: muriatic acid
    30 mins. with pump running.
    having problems? how often do you add acid?
    Re: muriatic acid
    I know this is late, but we just had to add alot to ours to drop ph and our pool guy said 6 hours..
    Above Ground 14.2 K Gallon, vinyl, Baquapure sand filter, 2.5 HP pump, K-2006 test kit
    Re: muriatic acid
    If the PH is very low, you don't want to swim. If you are just adjusting the PH to somewhere in the normal range, than 30 minutes with the pump running should do it. But if you are lowering the PH below the normal range for some reason, lowering TA and fresh plaster come to mind, then you don't want to swim until the PH comes back up to normal levels. If in doubt, test the PH after 30 minutes, and if it is in range, 7.2 to 7.8, you can swim.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: muriatic acid
    Quote Originally Posted by SweetSmiles
    pool guys say a lot of things. I've heard 4 before but 6 is the longest I've heard yet. I don't think anyone will melt 5-10 minutes after addition, but best to be on the safe side...
