Thread: I keep adding borax every couple of days.
    Mar 2009
    NJ
    215
    10-12 oz every time. Is this normal? I'm going by pool calc numbers.
    My ph seems to stay on the low side. I think it is from my swg not producing chlorine regularly. I think it makes too much, then I have to shuit it down for a while so the Fc levels go back down. During this time, the borax is needed. That is my guess, at least.
    Here's a sample test result.
    FC 4.5
    TA 90
    CYA <40
    CH 90-100
    PH 7.35
    Salt 3100
    My swg system does a good job lowering ph when needed, but like I mentioned above, it doesn't need it that often.
    The 4.5 FC is on it's way down from 6.5
    Hmm, after reading this post, it seems not just a borax question. Not sure where to put this question.
    Either way, I'm running out of borax! lol
    18' x 54" Round AG 7500 gallon w/small prefab 2-piece fandeck
    Waterways 200sf Cartridge Filter, 1.5 hp 2-speed pump. 2" pvc piping
    Pool Pilot Total Control swg w/acid tank feeder
    Pool Rover Jr., BBB, TF 100 test kit
    Guest
    Re: I keep adding borax every couple of days.
    If your pH is too low and your FC is to high then your total control system is not correctly set up.
    Mar 2009
    NJ
    215
    Quote Originally Posted by waterbear
    I'm sure you are right, but does one issue go hand in hand with the other? Technically. the ph gets low when the system does not produce chlorine for a full day or so. I'm having to shut it down somewhat because FC levels get too high. When fc levels are high, the ph levels are good because the system adds the muriatic acid when needed. It is only when the FC levels are low, that the ph seems to drop and I have to add borax.
    I'm actually still trying to adjust orp levels (yes, a futile effort!) on the system. So do I have to live with the adding borax until/if I ever get it fixed? Why does ph go down so fast? We have one adult and two kids swimming every day or other day for a few hours each time. Pump on low speed 24/7 at this point while adjusting orp levels. No aeration of any kind really, other than swimming.
