Thread: testing
    what is the best(easiest, Im new at this) testing method to check my water?
    24 x48 above ground pool.
    hayward sand filter
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    Re: testing
    start by reading pool-school/
    as you work your way down you will come across the article that talks about the test kits recommended by this forum.
    Re: testing
    The two test kits we recommend are the easiest, most cost effective, accurate test kits that our collective experience has come across. Anything else just doesn't come close and is going to be a waste of money.
