Thread: Quad 60 D.E. Filter bleed air valve broke, now out $$$$
    Jun 2007
    Eastern NC
    Why is it that things go wrong on a Friday late afternoon when everything is closed and nothing is open until Monday morning for you to get parts to fix your pool? Also when you do go in you find that the part you need is always a back order item and will not be in for a week. Don't pool company's keep stock?
    The bleed air valve on our filter system broke which in turn pumped out water for who knows how long all over the inside of the filter pump house. To the point that it got into the pump motor and burned it out which in turn tripped the circuit breaker. Needless to say I was able to get a new motor the next day, lucky for me it was their last one. But the bleed air valve was a now where to be fount item. I finally got a hold of a store online in Las Vegas that had one and they are second day shipping to me. So I hope to have it by Tues. Meanwhile the algae has taken hold and I have a nice green pool. I have the pump on circulate for now since I can't use the filter. What a mess.
    Sorry to vent but it really bothers me that this stuff happens when everything is closed and you can't get what you need right then and there.
    24k IG Vinyl D.E. Filter, SWG
    Re: Quad 60 D.E. Filter bleed air valve broke, now out $$$$
    Since you can at least have the pump on circulate, you can still keep enough chlorine in the pool to kill the algae.
    I know how you feel, though.
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
