Results 1 to 9 of 9
Thread: The Green Pool
    Apr 2008
    North Carolina
    10
    The Green Pool
    I don't have one of the recommended testers so I have to use the Wal-Mart tester and the local pool store. I know, I know, by the good tester but waiting on funding.
    I have been dumping bleach like there is no tomorrow with no luck at all, so please HELP.
    CYA 28
    FC >5
    CC ?
    PH 7.5
    24' Round 52" OG, new vinyl liner, 1 1/2HP pump using sand filter
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: The Green Pool
    Is your water green? Or you can't hold chlorine?
    Apr 2008
    North Carolina
    10
    Re: The Green Pool
    As Green as Green can be
    11,969
    Re: The Green Pool
    Well, lets round up and call your CYA 30, and that your shock level is 12. YOu need to add enough bleach to reach 12. (You'll have to dilute your water sample 50/50 with distilled water to see if you're getting close to that level with your OTO chlorine test.)
    So you add x number of jugs. You wait 30 minutes, your chlorine is only up to 6. You add more bleach, again trying to reach 12.... you wait another 30 minutes you test, you're chlorine is at 8....and so on....you need to keep adding bleach until your reach 12 and then hold it there, with frequent bleach additions, testing hourly and adding bleach each time to hold the shock level until the pool clears. You don't want to let the chlorine drop in between.
    Do you know how to use the Pool Calculator to determine how much bleach to add each time, to reach 12?
    Remember to run your filter 24/7. Is there any organic crud at the bottom, like leaves...etc.?
    Apr 2008
    North Carolina
    10
    Re: The Green Pool
    Yes, I know how to use the pool calculator.
    I will add bleach until I reach 12 and maintain that until the pool go clear.
    Thanks for your help.
    Apr 2008
    North Carolina
    10
    Re: The Green Pool
    Alright the pool has finally lost the green but is now cloudy. Do I continue to monitor the chlorine level and keep an eye on the filter or what?
    Kids want to swim...
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: The Green Pool
    without a fas-dpd test you have to keep shocking until it's clear. one of the several reasons this site recommends the kit.
    Casey's Avatar
    SW PA
    10,421
    Re: The Green Pool
    Quote Originally Posted by UGOWEGO
    Please do NOT let the children swim in a cloudy pool! If one would go under, it would be next to impossible to find them before it's to late!
    My kids are soon to be 14 and 12 and good swimmers and I would never allow them into a pool, even if they could stand, if it were green or cloudy. The fear just goes right through me of what could happen in a split second.
    Continue shocking.
    Re: The Green Pool
    Dead algae must be filtered out. Clean the filter as needed.
