Thread: Jacuzzi sand filter - need help with 7 way valve
    Bought a house with an older above ground pool that I've pretty much rehabed.
    Only thing left to do is figure out which setting on the filter does what.
    If anyone has a Jacuzzi sand filter with a 7 way diverter on top, I could use some help figuring out which setting does what. It would be easier if the sticker with the settings hadn't been torn off.
    edit: it's a SplashPak SS-160
    If you have one of these, would you please list the settings in order either clockwise or counter-clockwise, I think I can get it working. I can tell where the "whirlpool" setting is and I think I can make out the word "rinse" on one part.
    thanks all.
    and as this is my first pool, I'll be doing a lot of reading.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Re: Jacuzzi sand filter - need help with 7 way valve
    I think your positions are the same as the Vari-Flo:
    12:00 Filter
    2:00 Waste
    4:00 Closed
    6:00 Backwash
    8:00 Recirculate
    10:00 Rinse
    The seventh "position" is just an in-between position that's labeled "winterize" which just holds all ports open.
    that seemed to do the trick - thanks!!
    now to let it run for a little bit so I can figure out that chlorine generator thingy
