SWG and Above Ground Pools?
FlyboyTR
82
Mobile, AL
We are considering a SWG for our (soon to be installed) above ground pool. Will the salt have a long term effect on the walls and framework of the pool? Everything appears to be galvanized...but concerned about the long term exposure. Thanks!
Travis :-D
No, the frame should be fine. There is a small chance of corrosion only if there is a leak that doesn't get fixed for a long time. That could cause salt to accumulate on the frame. Leaks are bad regardless, you should be keeping an eye out for them anyway, so there shouldn't be a problem.
