Results 1 to 14 of 14
Thread: replacement motor bearings for A.O. Smith
    May 2008
    central Florida
    27
    returned from 1 week vacation to a screeching pump motor - not horrific, but I wouldn't want to spend several hours out on the patio having to listen to it. thought, "great another $200+ for a new motor". looked in my records and saw that the motor is only 4 years old. I figure it should last longer than that -- it's a one-speed, but we only run it 8-10 hours a day.
    I'm not 100% sure it's one of the bearings, but it sure sounds like it. the noise is coming from the non-shaft end of the motor and there's nothing on that end that's in motion except the bearing.
    I want to make sure I'm ordering the correct bearings before I disassemble everything. poolcenter.com has what I want -- I think.
    http://secure.poolcenter.com/prodinfo.asp?number=6304LL
    a 2" OD bearing
    my motor is an A. O. Smith 48Y frame with the square flange, 1.5 HP, 1-speed, service factor=1.1, 220 v
    is the above listed bearing the one I need? I figure I'll order the Go-Kit and the 2 bearings. any advice swapping out the beaings? any "gotchas" out there I should know about? thanks.
    12K gal PebbleTec, 1.5 HP 1-spd P2RA series Sta-Rite pump, Hayward cart filter, Pool Pilot SWG, spillway, no heater, sunny, Taylor K-2006 test kit.
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Re: replacement motor bearings for A.O. Smith
    for how much you are going to pay for that bearing + shipping if you paid a little more you could have a motor shop do it for you don't forget you need a bearing puller.
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
    Guest
    Unless Aladdin had changed their packaging the GoKits include the bearings.
    May 2008
    central Florida
    27
    Quote Originally Posted by X-PertPool
    true, I expect the bearings delivered will be in the $40 range. my neighbor has a bearing puller -- he doesn't know yet that I'm going to be borrowing it I like to try things at least once and am somewhat mechanically inclined, so I thought I would give it a shot -- maybe I'll post pictures of the process for others to use as motivation to DIY!
    Guest
    I just had mine replaced by a shop. It was about $90, and I had it back in 3 hours! Well worth it to me.
    Sue
    May 2008
    central Florida
    27
    Quote Originally Posted by waterbear
    the Aladdin gokits on poolcenter.com don't include the bearings. is there a better source for the gokits?
    http://www.poolcenter.com/service_re...epair_kits.htm
    X-PertPool's Avatar
    Exeter, PA
    1,385
    Quote Originally Posted by spriteman
    Don't forget if you pay someone else to do it there is someone to blame if it doesn't work
    -Kevin
    X-Pert Pool Service
    x-pertpool.com
    Guest
    My mistake, I haven't looked at the Aladdin catalog in a while. The go kits contain seals but no bearings.
    MJCP's Avatar
    Sep 2007
    Michigan
    129
    Please do post photo's.
    I just went through putting in a new motor, because I wasn't 100% confident I'd be able to pull off the bearing job. If there would have been any problems I would have kicked myself, so instead I went for the new Motor. But I love to "learn from others mistakes" So you might just convince me that next time I want to DIY.
    Thanks
    15x32 Lazy L Inground / Concrete - 20,000 US Gal 1979 build
    1.0Hp Maxiglass/ Sand Filter, 7th season with Pool
    Painted cement finish repainted 2011
    400,000 btu Pentair Master Temp NG
    May 2008
    central Florida
    27
    Quote Originally Posted by MJCP
    did you keep the old motor? if so, go ahead and order the bearings and attempt to swap them out. worst case, you'll be out the cost of the bearings. best case -- you have a motor ready to go as a spare and you gain the experience of DIY (plus, you can take your time )
    launboy's Avatar
    Jun 2008
    S.E. Wisconsin
    582
    Call around to motor shops. We called a REAL small place here and the guy did the bearings while we were there. Took him maybe 1/2hr and he only charged $25.00.
    Adam
    18' x 42" Intex Easyset Pool, with 16' x 52" deep end in the middle. Approx. 5500 Gal.
    Hayward Power-Flo LX 1 HP, 100# Jacuzzi Brand Sand Filter(Piped underground so it looks nice) 8)
    3 - 2' x 20' Solar Pool Heater Panels(roof mounted)
    Goin' on 9 summers...NOBODY thought it would last this long.
    Buried Portable Spa sharing pumps and water with pool (Almost complete project)
    MJCP's Avatar
    Sep 2007
    Michigan
    129
    YES!!!!
    My wife has been on me for two weeks to throw it out, but I just put it in the pool shed,
    Now I can tell her - "YOUR" idea and say YOU said I should keep it!!!
    I love a reason to keep STUFF!
    May 2008
    central Florida
    27
    hey I'm in the dog house enough as it is -- now your wife will be on my case too?! aaahhhhhhhh!!
    22,553
    If you have a bearing place close (motion industries, etc.) or even an auto parts place you should be able to pick up those for a song. Just call them and tell them you need sealed 6304's. The real number is 6304-2RS. They're about $5 a piece and if you pick them up locally there's no shipping.
