Thread: Newbie needs pump help
    antipode's Avatar
    Jul 2009
    Long Island, NY
    33
    Just opened the pool for the season and the pump made a high pitch noise, did nothing, and then smoked. Then, it was silent.
    OK, so:
    A) it's dead, right?
    B) how long should a pump last?
    C) how much should I spend for a new pump for a 12x24 above ground pool?
    12'x24' Oval Above Ground (Partially Buried)- 7000 gallons (est.)
    SwimPro Sand Filter
    Current pump: Hayward, 1.5 HP, SF 1, 15 amp (soon to be replaced)
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Newbie needs pump help
    C) Perhaps around $200 or less, depending on what you get.
    B) My pump is 8 years old.
    A) I don't know....
    A) The motor is likely dead. Not the pump. Check circuit for juice first.
    B) Mine lasted 6 years. At least 2 with the seal between the pump and the motor leaking. I bet that caused it to fail.
    C) I could have got a reman motor for my Hayward northstar from a place in Phoenix AZ for about a C note. Found them searching motors on ebay. If you are handy and not afraid to mess with your pump, then look into replacing the motor. (with a new seal of course) Get the numbers off the old pump and start searching the net. The search may get you a deal on a complete unit as well.
    16K gallon, Pebble tec, beach entry. Two 1 hp Pentair Whisperflos. One for Paramount MDX2 main drain, Paramount debris canister, and Pentair CCP 520 filter. One for skimmer w/sock and Paramount PCC2000 in floor cleaner. 3/4 hp Pentair Pinnacle for waterfall. Fiberstars fiber optic pool lighting. Aqua-Logic AQL-P-4 control panel with wired remote in the house. SWCG system that is not used. Ultra-Pure Ozonator that is not used.
    antipode's Avatar
    Jul 2009
    Long Island, NY
    33
    UPDATE:
    Thanks for the suggestions.
    I just went out to try the pump one last time. It has juice again: it tried to pump but only made that high-pitched noise. The shaft seems to be TRYING to turn but just won't. I quickly unplugged it.
    SwimPro Sand Filter
    May 2008
    Virginia Beach, VA
    84
    Sounds like there was a leak that let water get inside the pump and the bearings have frozen. Sometimes this can be repaired with new bearings at a machine shop (sometimes even the local pool store can do this), but you will also need to find the source of the leak (tiny cracks in the wet end of the pump can be hard to spot).
    Pumps can last for years, but a leak will quickly kill them.
    Depending on the price and the age, sometimes it's just better/nicer to replace the motor and wet end together, if it's a relatively new pump, you might want to try to get it checked and keep the current wet end (if there is no leak!). Just depends on the damage and what you want to spend.
    Good luck!
    28K IG Vinyl lined pool - 1 skimmer, 2 returns
    Hayward DE 60sqft filter; Polaris 280 vacuum with booster pump
    Here is the Phoenix pump/motor repair place:
    http://www.perryspoolpump.com/
