Results 1 to 11 of 11
Thread: Sunheater or Sungrabber?
    Vero Beach, FL
    462
    I'm looking for some low cost solar panels. Both Sungrabber and Sunheater are about $200 on the internet per two, 2' x 20' panels. Any differences?
    25' x 13' Roman, 12000 gal IGP, Plaster, with 500 gal Spa
    SWG, 1 HP Max Flo Pump, C-900 cartridge filter
    Solar heat
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    Re: Sunheater or Sungrabber?
    Quote Originally Posted by lborne
    I got the Fafco Solarbear heating system...it is a single piece 4X20 solar panel...no plumbing panel to panel to pool...just panel to pool and about 20 minutes of set up and istallation. I paid $280 for mine and no sales tax...out of a pool place in Florida
    aquasuperstore.com
    http://www.aquasuperstore.com/products/ ... ~3664.html
    They are only $242 right now with $35 shipping...no tax because it is in florida...That is about 20 less then what I paid for mine in May. I'd go for it.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
    I had 3 pool installers telling me that the pannels suck they are only 2-3 years old and being replaced .They told me to buy this Dome system.http://www.poolsupplies.com/cgi-bin/Com ... key=902517 think this is what hes talking about.
    NWMNMom's Avatar
    Waaay NW MN
    1,582
    Panels work great for us and have for many years. The Fafco Sunbears do work the best so far for quality in our experience. We used the Sunheaters and Sungrabbers in the past. The Fafcos are better quality and as stated before 4x20 so less panels to install.
    18x33x52 Buttressfree Seaspray (Wilbar) AGP - 1.5hp Pentair Maxim w/22" Pentair Meteor Sand Filter, Aqua Rite SWG System, Biltmore Walk In Steps - 2/4x20 Solar Panel Setup - Doheny Jet Drive (RIP -Pool Rover Jr) - finally hard plumbed the whole darned thing -
    Beats Driving to the Lake!
    dmanb2b's Avatar
    Apr 2009
    NY
    3,734
    Another vote for Fafco Solar Bear Panels...single 4x20 panel, very well made...sturdier than the sungrabber panel also made by fafco...IMHO
    Jul 2007
    Northern NJ
    299
    Quote Originally Posted by Vistal
    Did you buy it? If so, how is it working?
    Nicole
    21' AGP (10,400g)
    Hayward PowerFlo Matrix dual-speed 1HP pump, 75 sq ft Waterway cartridge filter
    4G Liquidator, Aquabot POOL ROVER S2-40
    Feb 2008
    Northwest Indiana
    900
    My Solar Bear heats six to eight degrees in one day depending on the situation. I think it does so because of the 20 X 4 length and width...more sun hitting more area. This little thing doesn't have as much area to hit and thus doesn't heat so fast. For a 24 foot pool, I have mine on the side away from my house I cannot see it from my house...My neighbors probabaly think it is a monstrosity but it it certainly works.
    Beave
    Vero Beach, FL
    462
    Those solarbear 4x20 panels look great, but they are for AGP. I have an IGP.
    Solar heat
    Feb 2008
    Northwest Indiana
    900
    They work the same as the sungrabber or sun heater panels...They can be plumbed to run into your pools plumbing system...and could be mounted on a roof somewhere if needed.
    Beave
    Vero Beach, FL
    462
    Quote Originally Posted by cubbybeave08
    Can someone please explain how easy or difficult this is? I'd like to hear from anyone who has used these for an inground pool and what mods you had to do to plumb it. I will need two of the 4'x20' panels. Can they be mated together?
    Solar heat
    Feb 2008
    Northwest Indiana
    900
    I have an above ground pool and yes your two pannels can be mated. It is as simple as connecting them...I think FAFCO actually sells a connecting kit. All you really do is run one end from the outlet line of the filter ( the line that runs to the return jet) to the lower end of the SolarBear panel. Then run a hose from the top end of the panel to the return jet. This completes the cycle. When the valves are shut off the water runs straight up the pipe and into the pool...when it is turned on the valve inside the Solar Bear actually blocks off the flow up the pipe and diverts it through the panels. This causes the water to pick up the heat from the panels and out into your pool...It took me about 1/2 an hour to hook mine up to my pool. For an inground pool it might be a little more complicated but you might want to see the thread below
    adding-solar-bear-panels-to-our-agp-the-process-with-pics-t11410.html
    This might help you to atleast see how it might work with an inground pool.
    Beave
