Thread: How do I lower my CYA
    Jul 2008
    New Jersey
    63
    Pool water is great now except for a CYA level of 100, it is 33K gallons , can I top it off with fresh water till the top of of the pool . that would give me about 6-7 inches of fresh water , and then wait a couple of hours for it to circulate then pump out till bottom of skimmer and then refill, if I do that a few times will I eventually get the CYA level down ?? I don't want the watrer to drop to much and damage the liner ? THANKS
    33,000 Vinyl Liner IG Pool, Hayward Sand Filter,Hayward Superflo Pump,Auto Pilot Dig 220 w/RC-52 cell, Polaris 9300xi cleaner. 4 wheel Pressure PoolCleaner.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: How do I lower my CYA
    you have to replace water. how you do it is your choice, but you're going to have to do half of the water to get it down to 50. I manage mine at 70 if you would rather stop sooner. you just run a bit higher fc level per the chlorine/cya chart.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    It's usually safe for most pools to drain down 1 foot, refill, retest, repeat if necessary.
    Feb 2008
    Denton, TX
    5,061
    Quote Originally Posted by frustratedpoolmom
    Yep, that's probably the best way to go and it is how I did mine when my CH was through the roof. It takes more water that way but you don't have to worry about hurting things.
