Thread: replace a pool liner???
    I need to know how to replace an above ground pool liner that has J hooks? Please help!!!
    24' Above Ground Round 13,500 gallon...Hayward sand filter
    1.5hp Pump
    Former Baquagoo victim... Now GOO FREE!!
    1 Man 3 Women Leisure Bay Santo 300 gallon hot tub ... 763801706/
    X-PertPool's Avatar
    Exeter, PA
    Re: replace a pool liner???
    I would highly recommend measuring the depth of the pool and either try to smooth the bottom out so that the depth is overall universal throughout the pool. If the depth measurements from the floor to the track are slightly different from one spot of the pool to another go with the shallowest measurement as the liner will stretch into place but extra material will just wrinkle. insert the beaded liner into the track and reposition to get the liner true to the pool. I recommend ordering a custom liner with depth measurements to get the best fit. Depending on the type of pool you may need to disassemble the top rail to get the liner onto the track, when everything is in place use a shop vac to suck the liner against the wall and smooth out any wrinkles then fill and cut your done.
    X-Pert Pool Service
    X-Pert Pool on Facebook and @XPertPoolServic on Twitter
    22,000 gal / 16' x 32' / Vinyl / Hayward s244t /Pentair SuperFlo 1 hp
