Thread: Return jet aimed to high?
    I just posted a pump issue, but thought it was best to post this one seperately. Our pool was installed yesterday. We have the filter running and the return jet in the pool is aimed away from the skimmer but we think is aimed too high because we can see lots of bubbles on top of the water- we hear the water jetting in and we see the water jetting in. We have tried moving the 'eye' but it doesn't move. We believe it is aimed in the right direction but too high. How do we lower it so it returns the water lower into the pool. Thank you.
    24' x 52" AG round - 13,500 gallons - 2hp 2 speed BaquaPure pump, Pro Clean cartridge filter, TF-100 Test Kit
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Re: Return jet aimed to high?
    There's usually a ring around the eye that you can turn ccw and loosen up so you can reposition the eye, or you can insert a screwdriver into the eye and use it to aim the eye.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Thanks Mike, we haven't been in the pool yet We have been trying to move it by putting our hand down in the pool and had no luck. We haven't gotten our steps in the pool yet, but are going to put up something temporary so we can put the steps in until the deck is done- which hopefully will happen soon! We will try it as soon as we can. Thanks again.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    I've found that when trying to loosen that ring from the top, a rubber glove really helps you get a good grip to turn it with. Oh, and if you do it this way, remember that the eye will turn a bit when you tighten the ring up, so compensate for that when you tighten it.
    and you're very welcome!
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Thank you! My husband was able to move it with a rubber glove on his hand! Sure is a lot quieter now!
