Thread: I can't figure out what happened - please help
    Jul 2007
    Memphis, TN
    19
    I have been following advice from this forum for 2+ years. I opened the pool later this season than before, but, never experienced this problem. This is the first time in 2 years that my readings are not good. Please help me figure out what might be wrong. Thanks in advance.
    TH=100
    TC=.5
    FC=.5
    pH=7.2
    TA=80
    CYA=20
    23k gal IG Gunite
    Haywood S-220T - Sand Filter
    Guest
    Re: I can't figure out what happened - please help
    First of all, how are you testing your water? You have total hardness, which is a test strip test and NOT a drop based test so you are not following our advice if you are using strips.
    Your CYA is low which might very well explain the low FC readings.
    However, If you are using strips, which I suspect you are because of the TH reading then all your readings are suspect.
    Other than the low CYA and low chlorine (which are easily fixable by just balancing your water) what problems are you having? All your other readings are OK except for the CH if your pool is either plaster or fiberglass.
    Since you have a plaster pool I suggest you get a test for calcium hardness and NOT total hardness and add calcium to bring the level up.
    Jul 2007
    Memphis, TN
    19
    Waterbear - you are right about that reading - it was from strips (until my reagents came)- my drip testing was on the other side of the paper and here they are:
    FC=2.5
    CC=.5
    TC=3.0
    pH=7.8
    TA=70
    CH=110
    CYA=25
    Thanks for picking up on that. and for your help...
    23k gal IG Gunite
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    So is the water clear, you just can't hold FC?
    Guest
    This reading is a bit different! You need to raise the CH and the CYA and you might want to shock to get rid of the CC but otherwise your numbers are not too bad. Keep an eye on the ph and lower it if it goes any higher.
    Jul 2007
    Memphis, TN
    19
    Yes, the water is clear and I will start on raising he CH and CYA. I'll post again. Thanks.
    23k gal IG Gunite
