Thread: Pump Pressure - When to backwash
    My 1st post, not sure about layout....
    I've just refurbed my pool (1st pool I've owned) The pump pressure stays at 18psi after backwashing. What is (are) normal pressures? At What pressure do you backwash?
    21,000 gallon Lazy L IG, vinyl
    16 ft wide, 32 foot long, 7.5 feet deep
    Pentair Challenger pump 1 hp
    Tagleus sand filter
    Pentair 320 in-line cl feeder
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    Re: Pump Pressure - When to backwash
    It depends on how your water flow is affected by the increased pressure, but typically you have to backwash after an increase of 5-10 psi.
    pool4me's Avatar
    Sep 2008
    Bucks County, PA
    My Hayward filter instructions suggest backwashing when pressure increases 6-8 psi over the "clean pressure".
    On my setup, I seem to "hang" right at 15psi (right now after new sand and first backwash). I'll usually backwash when it get's to the 20-23 psi range.
    33'x15' x 52" Aqualeader
    Gallons ? - (I use appx 13,500 to calculate "stuff")
    33 x 15 x 4.3 x 5.9 = 12,558. or . . The Pool Calculator = 14,400
    Hayward S-166T 100Lb Sand Filter - Hayward Power-Flo LX 1HP Pump
    Intex S.W.G.
