Thread: where can I get the Taylor k2006 test kit?
    Jul 2009
    ontario, canada
    16
    Does anyone know of a pool supply place in Indiana (Fort Wayne area) or Michigan (Detroit area) that might stock the Taylor k2006 test kit or equivalent? Friends are driving through and can pick one up for me - save me the higher Canadian pricing - but I'm not having any luck finding a store that stocks it.
    Thanks for any leads!
    31050 gallon, inground with 7'8" deep end, zodiac d200 swg, Hayward 250,000 btu led heater, 450 sq ft system 3 cartridge filter, 1hp sta-rite pump, navigator pool cleaner (that only likes to clean the deep end), solar blanket (with clear deck), 2 main drains in deep end, shallow and deep end skimmers
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: where can I get the Taylor k2006 test kit?
    Try a Leslie's. I believe they handle a similar kit under their own brand, but it isn't usually stocked. Maybe they can order for pickup.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    http://www.lesliespool.com/browse/Home/ ... 00/I/81329
    it is unlikely they have it and also unlikely it will be there in time (unless it will be a while before they come up).
    Jul 2009
    ontario, canada
    16
    thanks - I've been putting calls into Leslie's stores along their route - no luck so far. May have to pay the bigger Canadian price!
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    Where are they crossing? Windsor (bridge or tunnel) or Sarnia ?
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Here's a good on line source.
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP, 38 SF Anthony DE filter, 1 HP Hayward Super Pump
    380k BTU Raypak Natural Gas Heater (Model RP405A) and solar cover
    8 gal Liquidator w/ 12% bleach, Dolphin Diagnostic Advantage robotic cleaner. 3800 ppm salt, 50 ppm borates.
