Results 1 to 20 of 20
Thread: I'm new to this and getting frustrated ---
    Jun 2008
    Springfield, MA
    5
    I've been trying to use the BBB method this year and so far the pool is still a pale green.
    my numbers as of today are :
    FC = 12.5
    CC = 1
    TC = 13.5
    TA = 170
    CH = 190
    CYA = 28 -30
    PH = 7.8
    I'm not sure as to what to do next. I've been using a lot of liquid bleach from the grocery store. According to the chlorine/CYA chart I'm at shock level. AS I add more chlorine I get a light brown stain on the pool steps -which I believe is from tanins from oak leaves that are still in the pool. I've been removing them over time but since I can't see the bottom of the pool it's hit or miss. Am I close to the mark on these numbers ? Any advice is appreciated.
    thanks
    Eanjr715
    Inground vinyl pool 18 x 36 20,000 gal.
    cartridge filter 320 sq ft.
    1.5 hp pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: I'm new to this and getting frustrated ---
    Welcome to TFP!
    The leaves are the root of your problem. The chlorine you add is trying to break them down, and being consumed in the process. If you don't have a leaf rake like this
    get one so you can clean the bottom of the pool. The leaf rake is far better for this than anything else.
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    You wont be able to clear your water up until the leaves are out of the pool. Get a leaf rake and just dip it in and get what you can. If you can remember when debris collects in the pool under normal circumstances scoop there because thats where they will be most likely sitting.
    If you have a pool cleaner of some type put it in and let it run for a few hours and see what you come up with. Thats what I did this year and it did the trick !
    Les
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
    Butterfly's Avatar
    South Carolina
    10,045
    Hi EANJR715,
    Your numbers look okay. You are at/near shock level for your CYA
    As John & Tiz said, use a leaf rake/pool cleaner and get all the goop out! It is eating you chlorine!
    What test method did you use for your results? Kit (which one)? Pool Store?
    Have you read Pool School? Button/link top right of each page
    Can we see a pic of your pool?
    Welcome to the forum
    b/t/w, JohnT, nice pic of your sparkly pool water in your post
    You're done SLAMing when:
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    I thought that was from a magazine !
    Only kidding !
    Les
    Helpful Links:
    Jun 2008
    Springfield, MA
    5
    I'm using the TF-100 kit for testing the pool. I have a leaf rake - and have been using it - I guess I have more leaves in there than I thought.... will persevere!
    thanks
    Ed
    1.5 hp pump
    I dumped a large amount of bleach into my pool to open it. It wasn't until I got almost all of the organic debris out that I really started making progress. Like these guys said, the more you get out, the faster it will go and the cheaper it will be.
    26,000 gal liner IG pool
    Doughboy with concrete construction
    Full sun most of the day
    1.5 hp pump system
    200lb sand filter
    Jun 2008
    Springfield, MA
    5
    I've seem to have gotten most all of the organic material out of the pool. The leaf rake comes up empty except for the occasional leaf or two. The water is a dull white/very light green color. I've been putting in lots of 6% bleach. Measured this morning and the FC is quite high. I've vacuumed yesterday and didn't really get much in the skimmer basket. I can vaguely see the bottom of the steps going into the shallow end.
    using a lot of patience here !
    FC - 22
    CC - 2
    TC - 23
    ph = 7.8
    cya - 30
    Using the TF-100 test kit.
    1.5 hp pump
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    doing good. keep up the hard work.
    AnnaK's Avatar
    Jul 2007
    Eastern Pennsylvania
    1,134
    Now you wait. Keep the filter running. You might from time to time give the bottom and the sides a brushing but at your current FC level you're not likely to have anything growing in there. It can take some time for the filter to clean out the remaining organics and other fine debris.
    AnnaK
    12,500 gal AGP, Hayward sand filter, Pentair 2-speed pump, timer.
    Please visit our Pool Issues pages for information about step weights, managing the solar cover, and PoolSkim.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Hi Anna,
    are you saying he's done shocking?
    AnnaK's Avatar
    Jul 2007
    1,134
    With a CYA=30 and an FC=22 in my opinion Ed doesn't need to keep adding bleach for a few days. If this were my system I'd let the FC drift down. I realize that something is consuming the chlorine because he reports a CC=2 but given the amount of leaves that had been in the pool the chlorine consumption may be due to factors other than algae, such as byproducts from the breakdown of the leaves.
    I would test FC and CC daily and maintain FC at 15 once it gets there until the water is clear. That's my personal approach which has worked well when we had green water issues. YMMV.
    AnnaK
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    I agree with AnnaK ... let your FC drop back to 15 since your way above shock level anyway brush the walls and the bottom to keep any little stuff stirred up and let the filter work for a few days.
    Have you back washed the filter lately ?
    Once the algae is dead it can take up to a week for the filter to clear up the water. You should see improvements every day.
    One day you will walk out to the pool and you will get a pleasant surprise to a crystal clear pool !
    Be patient !!!!
    Les
    Helpful Links:
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Quote Originally Posted by AnnaK
    gotcha. the way I read this was, you dumped a bunch of chlorine in and got your level high so you're done even though the water's light green, cc's are 2 and no overnight loss test was performed. I've often been accused of wrecked trains of thought, but I just didn't want the op to think he was good to go.
    Butterfly's Avatar
    South Carolina
    10,045
    Ed, it does take some patience to clear a pool. A bottle or two of POP is often needed.
    The shock level for your CYA is around 12 or 13.
    Use Jason's Pool Calculator (link in my sig, on home page and in Pool School) to figure the correct doses of bleach/liquid chlorine to add to reach your shock level.
    15 is a little high, but okay.
    You are making good progress, but not done yet.
    You are done shocking when:
    1. Your overnight FC loss is 1 or less and
    2. Your CC's are .5 or less
    You have the TF100 and can precision test to verify.
    You can read detailed instructions on "How to Shock Your Pool" in Pool School.
    Jun 2008
    Springfield, MA
    5
    ok I'm starting to see the bottom of the pool (barely) in the shallow end.
    We've had a lot of rain and I 've had to remove water from the pool - at one point I took out too much and had to put some back via the garden hose.
    Current numbers
    FC 2
    CC .5
    TC 2.5
    Ph 7.5 - 7.8
    CL from quickie test kit is around 2 - 3
    CYA = 20
    According to the pool calculator I should add about 3.5 lbs of stabilizer to vring it up to 40 and
    2 182 oz jugs of 6% bleach to get it back to shock level.
    Am I on target ?
    Thanks
    Ed
    1.5 hp pump
    AnnaK's Avatar
    Jul 2007
    1,134
    Did you ever do an overnight FC test?
    If so, and if your chlorine loss was 1 or under, and given that the CCs test at .5, you don't really need to shock and save the bleach. I would bring up the stabilizer though. Your goal of 40 is appropriate, go for it.
    Happy to hear you can see the bottom!
    AnnaK
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    920
    I wouldnt add all of the CYA (3.5lbs). I would add maybe 3 lbs and see where that gets you too. Its easier to add smaller mounts then drain and refill water to get back to your goal you want.
    Les
    Helpful Links:
    Jun 2008
    Springfield, MA
    5
    ok will do. Sock of it in the skimmer ok to disperse it?
    1.5 hp pump
  20. Back To Top    #20
    22,550
    Yep, sock in the skimmer will work but tying a sock in front of a return is the more recommended method. Since you don't have to worry about losing it if you have to clean the filter.
