Results 1 to 18 of 18
Thread: Do you really need to fill gap between the concrete & coping
    Mar 2008
    Harrisburg, PA
    13
    We were told to fill the gap with some kind of caulking (after 2 years). We have to pull out the plastic filler material first & then seal the gap around the pool. I don't mind it being open. Will it cause repair problems if we don't seal it ... Water seaping under & cracking due to freezing & thawing?
    Harrisburg, PA
    18 x 38 IG Gunite/plaster pool
    Oasis form 18,500 gal
    Jandy Aquapure SWG
    orthofish's Avatar
    Jan 2009
    Northern Middle Tn.
    562
    Re: Do you really need to fill gap between the concrete & coping
    Could you post a pic?? I can;t answer your question, but a pic will help those who can
    Welcome to TFP
    Lynn
    16x38 FG, 20,400G, 1HP/2sp Tristar pump, Hayward 425sq ft cart. filter, Pro Logic4, SWCG, 3 returns, 2 main drains, 1 skimmer, 4 Pentair deck jets, Hayward Phantom pressure cleaner/booster pump, TF-100 of course :-)orthofish-s-pool-build-finally-t13179.html
    30,419
    Water seaping under & cracking due to freezing & thawing?You got it. Every splashout of that pool deposits water under your decking. Even if it doesn't freeze, that's not good for several reasons.
    Polyurethane caulk will give you the best, most permanent seal but is touigh to work with. Silicone is easier but doesn't look as nice. Acrylic will ineveitably shrink and reopen the crack.
    Why did they wait two years to tell you?
    Mar 2008
    Harrisburg, PA
    13
    Anthony & Sylvan told me to wait 2 years before doing it. I don't know why you have to wait.
    Harrisburg, PA
    Jandy Aquapure SWG
    kevreh's Avatar
    Jun 2007
    Annandale, VA
    403
    I paid about $300 for a professional to come out and do the caulking between the coping and concrete pads around my pool. My biggest concern was water getting in under the concrete and freezing. It took him a good part of a day. What he did;
    - Clean out old caulking. They used a razor to "free" it between the caulking and concrete then pulled it out.
    - Prepped the concrete by cleaning with a wire brush on a drill. Just the inside, not the top/face.
    - Taped off the top two sides so any spill-over caulking would be easy to clean up.
    - Mixed a 2-part caulking solution
    - Put it in a large grouting (or icing) funnel bag
    - Carefully applied
    Pretty straightforward, just tedious. After they applied it can't remember if they just let gravity settle it or if they came back with a tool and smoothed it.
    HTH,
    Kevin
    16x32 Concrete IG 24k Gallons
    Equipment: Carvin 525sf Cartridge Filter, Jandy Gas Heater, Vortex Solar Panels w/solar valve, 1hp Hayward Pump with 3/4 HP AO Smith 2 Speed Replacement Motor, Aquarite Saltwater Cell, Polaris 280 Dolphin Active 20 Robot
    Automation: Hayward Prologic Controller
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    I'm getting ready to use joint sealer between my coping and deck and see a large price difference between these joint sealers. Does anyone know if the more expensive brands are better; like Deck O Seal or Velkem?
    20x40 IG Vinyl, 1.5 HP Whisperflo, Sta-Rite System 3 (300) Sq. ft Cart
    Intellichlor IC40 SWCG, 125,000 BTU Pentair heatpump, Polaris 280
    7' IG FG Spa, 2 HP Whisperflo, Pentair Dynamic III Cart (100) Sq. ft
    reallytiredteacher's Avatar
    May 2009
    Southern Missouri
    38
    Keep us updated...we are pouring our concrete pool deck this week (DIY project) and I have no clue how to seal it. I am learning with you! Hang in there!!!
    22K gal IG Vinyl 18'x36' rectangle (Hydra Pool Kit, Homebuilt DIY Spring09) 8' deep end
    Aqua Genie (No Main Drain, No Separate Returns), Hayward 1.5hp Pump, 24" sand filter & 2" Pipes, Jandy WaterColors LED Light, Flyte DeckII/FibreDive Board
    :sun: Added for 2010~ SWG CompuPool CPSC36, "The Pool Cleaner 2x" suction cleaner, PICS of our DIY build, and our DIY Lime Green SLIDE refinishing project!
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Can you give examples of brand names for the Polyurethane and Silicone?
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP, 38 SF Anthony DE filter, 1 HP Hayward Super Pump
    380k BTU Raypak Natural Gas Heater (Model RP405A) and solar cover
    8 gal Liquidator w/ 12% bleach, Dolphin Diagnostic Advantage robotic cleaner. 3800 ppm salt, 50 ppm borates.
    TripleB4me's Avatar
    Jun 2007
    Maryland
    224
    I decided to use Vulkem 45 which is a polyurethane sealant. As soon as it arrives and I try it out I'll report on how it went.
    Mar 2008
    Harrisburg, PA
    13
    Tried to upload photo but was unsuccessful. Sounds like you all know what I'm talking about.
    Harrisburg, PA
    Jandy Aquapure SWG
    kevreh's Avatar
    Jun 2007
    Annandale, VA
    403
    Thats too bad, would be nice to see the finished job. Is the photo a .jpg file? Decent size (no more than about 500x500 pixels)?
    If you want send it to me at kevin2REMOVE_ME_BEFORE_SENDING@rehbeins.com and I'll post it for you.
    Kevin
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Quote Originally Posted by shazza
    Open a Photobucket.com account (or similar-many free sites offer photo hosting). Upload the pics there (select the "large" size when you do) and then copy the "IMG" code - it will give you several choices of code - then you just past the IMG code into your message here, and voila, the pic appears. SSSooOOO easy.
    Aug 2007
    Northeastern Ohio
    178
    Quote Originally Posted by frustratedpoolmom
    SSSooOOO easy.
    So easy a frustratedpoolmom could do it?
    Sorry - couldn't resist.
    ~30000 GAL In-Ground 26'x50' Kidney Shaped Pool
    Hayward EC-75 DE Filter w/1.5HP Hayward SuperPump
    daily user of JasonLion's Poolcalculator
    (12) 2x10 SunGrabber Solar Panels...now if only there was some sun to shine on them!
    Feb 2009
    West Virginia
    216
    Does the original filler look like this? Our pool builder never said anything about having to replace this stuff! We have been wondering about it though, because the stuff looks like it is slowly disappearing. This is our third summer.
    [img][/img]
    WV Girl
    Custom "L" shape IG gunite pool, 36K gal., main drain, 2 skimmers, 3 returns, hayward heat pump, hayward 1.5hp pump with booster pump, ozonator, 4 cartridge filter.
    one dear hubby, two waterlogged kids, and lots of good times!
    Mar 2008
    Harrisburg, PA
    13
    Yes this is exactly what I'm talking about. Our pool company told us to wait 2 years, pull out the plastic bubble stuff & seal the gap.
    Harrisburg, PA
    Jandy Aquapure SWG
    Mar 2008
    Harrisburg, PA
    13
    Will tackle "filling the gap" project this month. I hope to post photo and level of difficulty - haha!
    Harrisburg, PA
    Jandy Aquapure SWG
    Feb 2009
    West Virginia
    216
    Did you ever get your "gap" filled? How did the project turn out? Just wondering because we will have to do the same project sooner or later. Hoping to learn from your experiences.
    WV Girl
    Mar 2008
    Harrisburg, PA
    13
    Unfortunately we had other projects to do and we did not get to it. The pool is being closed today. We may still try to do it this fall if the temperature cooperates. We'd have to undo the safety cover to do it. It will definitely get done in the Spring. Top pool priority.
    Harrisburg, PA
    Jandy Aquapure SWG
